Old 04-21-2010, 01:41 PM   #1
PBFAB.COM
PBFAB.COM's Avatar
60-66 Hood Hinges
60-66 Cowl Mounted Hood Hinges $225 Shipped (continental US)
By Porterbuilt Street Rods
It was only a matter of time before we dialed in our cowl mounted hood hinges for the 60-66 C10s. We have been offering a re-locator bracket for the factory hinges for a few years now, but they limited the overall tire diameter to 27”… that kept the wheel selection to a 20” rim. These new cowl mounted hinges will allow the frame-rails to touch-down without tire to hinge clearance issues. The Install is simple and straight forward, and requires some cutting of the cowl panel, welding a mounting pad to the rear hood hinge support, and of course… careful measuring!
Here’s a quick installation write up on the hinges… look for a better write-up in the near future!
The hinges need to be mounted 45.625” apart (that’s 45 5/8). Find the center-line of the cowl and make a reference mark. There will be mounting hole real close to center where the cowl panel screw mounts. Once the center-line of the cowl has been found, measure out towards the fenders 22.8125” (that’s 22 13/16”) and make a reference mark. This will be the center-line location for the hood hinge pockets.
It will be necessary to cut a hole in the cowl so the hinge pocket can be installed. Make sure you leave a small lip on the front of the cowl for strength, and also be careful as the cuts will get close to the wiper mechanism.
Make a template of the hinge pocket mounting holes with posterboard or paper and transfer the pattern to the cowl.
Drill the holes and cut the slit for the hinge arm. I find it easiest to drill two holes at the top and bottom of the slit and then connect them with a cut-off wheel.
Install the hinge pocket and hinge arms (there is a RIGHT and a LEFT side. The bottom of the hinge pockets are angled to follow the slope of the cowl). The pocket will be installed first, and then slide the hinge arm through the slit. Check for clearances and make adjustments where necessary. Install all mounting hardware.
Just like our 67-72 hinges, there is a mounting pad that needs to be welded to the hood brace on the underside of the hood. The heat from the weld WILL NOT affect the exterior paint. Just as with the cowl panel, you will need to find the hood brace’s centerline. There are a couple of holes in the brace that will be near dead-center. Make some measurements to verify this.
The hood mounting pads’ centerline needs to be the same as the hinge pockets’…45.625” (45 5/8) once centerline is found, make a mark. Measure out 22.8125” (that’s 22 13/16”) and make a reference mark on each side. This reference mark will be the centerline for the hood mounting pads. The back of the mounting pad will measure 1” off the rear edge of the hood brace (see picture below). Verify this measurement to be as close as possible. Careful measuring during this portion of the install will make things much easier! Set the mounting pad in place on the hood, verify measurements, and clean the surface before welding. Tack the pad in place and test fit the hood.
Once the mounting location of the hood pads has been verified and test fit, remove the hood and fully weld the pads to the under-hood brace. Install the cowl panel before the hood goes on for the final time. There is ample fore-aft adjustment for the hood to set the gap at the cowl, and there are also shims available (if needed) to adjust the height of the hood at the cowl.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 04-22-2010, 10:20 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: 60-66 Hood Hinges
Sweet new product Nate. The 60-66 should love this.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
