Old 04-26-2010, 12:38 AM   #1
Stano
Stano's Avatar
rusty gas tank liner or cleaner
I have a question that isnt truck related but may be of some use to someone with the same issue on truck. I have a 46 minneapolis moline tractor and the tank had lots of condensation get in it and rusted the inside pretty good. I put stones in it and rolled it around and vaccumed it all out but I am still getting rust in my fuel line and filter and plugging it up. My question is what have you guys used to line tanks to seal em up and or cover over crud on the inside? If it was a vehicle I would opt for a new tank but that really isnt an option here for me. I know people have used this kind of stuff on vehicle tanks but I never have and only want to do it once. Let me hear your ideas or recommendations. I have been fighting this problem for over a year.Thanks.
New daily driver 96 Chevy K3500 crew cab dually 53,000 miles 350 Vortec 4L80
Nice ride 67 Chevy C-10 LWB Built 350 TH-400
Wifes ride and family rig:
2001 Furd Expedition 5.4 Liter
Kickin back in Rolla,Mo. USA
"Do the thing you fear most and the death of fear is certain" Mark Twain
Stano is offline   Reply With Quote
Old 04-26-2010, 06:36 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: rusty gas tank liner or cleaner
Buy a gallon of muriatic acid (swimming pool acid) at Walmart, Home Depot, etc...
Seal all tank outlets but one. I use duct tape. Pour in a quart or so of acid and fill the rest up mostly full with water. Cover last opening. Turn and shake the tank in all directions. Be damn careful, that acid is the real deal. Drain tank and check. You might need to do it several times but you will wind up with a dead clean tank.
Once tank is shiny metal inside, flush very thoroughly with water. I run the garden hose in it for an hour or more.
Drain and dry tank by running air through it with either a fan or air hose.
Seal with POR15 tank sealer. Do not use Redkote or Kreem. Both of those products have proven to be poor long term solutions.
I have fixed a lot of tanks this way and it flat works. I do a good bit of motorcycle work and many of the tanks are simply irreplaceable so it's either fix them or nothing.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 04-26-2010, 09:08 AM   #3
kernalklink
kernalklink's Avatar
after using water to flush it - you can dry the tank with M.E.K. - it absorbs water and flashes dry quickly so there are no worries about missing any. 1 quart will absorb about 3 ounces of water. its about $10 and you should be able to get it at your local HW store - like mentioned above take it easy with this **** though; get a vapor mask probably
drying the tank with compressed air can add water if there is condensation in the air tank
Methyl Ethyl Ketone
1967 K20 'the white truck'
sm420/Rockwell t221
Dana 44 front w/ Dana Spicer 1/4 turn lockouts
Eaton Ho52 rear
"holy **** this thing is a tank!"
As soon as your born you start dying so you might as well have a good time!
kernalklink is offline   Reply With Quote
Old 04-26-2010, 07:44 PM   #4
Stano
Stano's Avatar
Ok thanks guys I appreciate it. I really need to get this old workhorse runnin good and do some brushogging. LOL
Old 04-26-2010, 09:31 PM   #5
kcfirstbuild
Kbs makes a Gas tank coating I just used it !! Seemed to work great !
kcfirstbuild is offline   Reply With Quote
Old 06-19-2014, 10:10 PM   #6
imjeff
imjeff's Avatar
X2. Many an old Harley and Indian tank have been saved with this method.
I know a guy who's addicted to brake fluid. He says he can stop any time.
72 K10 396
75 Cj5 MPI 350 Chev
67 Chevelle 396, 4 speed
74 FXE
08 Tahoe
imjeff is offline   Reply With Quote
Old 06-20-2014, 09:54 AM   #7
Daner
Daner's Avatar
When I sealed the tank on my old Honda bike I used a piece of chain to knock the loose stuff out. Then sealed it with some blue tank sealer. That was probably 6-7 years ago now. I don't remember what it was called.
Dane
67 Chevy Fleet 250/4 speed 1/2 ton
68 Chevy 250/4 speed 1/2 ton for parts
49 GMC Grain truck 235 1 1/2 ton
76 Chevy 350/4 speed 1/2 ton
Daner is offline   Reply With Quote
Old 05-06-2015, 01:27 PM   #8
kvn1011
Kvn1011
kvn1011's Avatar
for the stock 67-72 truck tank
would one quart be enough to seal
the tank?
kvn1011 is offline   Reply With Quote
Old 06-19-2014, 08:19 PM   #9
ChefCy
ChefCy's Avatar
subscribed. any recent solution options?
acetone?
63 big window lwb bagged and shaved
ChefCy is offline   Reply With Quote
Old 06-19-2014, 09:46 PM   #10
69 MOD
69 MOD's Avatar
Go to Orilley's and buy this to coat the tank.
We use it on our vintage snowmobile tanks with very good results
(even covered a larger than pinhole leak for me)
Chad
'71 GMC 2500 Custom Ol Blue
'72 Custom Deluxe Highlander Stuffed Olive
'73 Trans Am
'13 Silverado 2500 Duramax Storm Trooper
69 MOD is offline   Reply With Quote
Old 05-13-2015, 09:01 PM   #11
kvn1011
Kvn1011
kvn1011's Avatar
answer: one quart would work
