04-26-2010, 06:19 PM | #1 |
07 silverado brake controller help
does any one know where the aux stud is on the fuse box, under the hood. and what is the fifth wire under the dash (chmsi) for ! any pics would help thanks for looking
04-26-2010, 07:52 PM | #2 | |
C-10 Club Member
Re: 07 silverado brake controller help
I will find you the info tommorow. nnbs 07+ dont have a fuse. There is a wire you connect with a nut in the fuse block. |
07-23-2010, 05:08 PM | #3 |
there are two wires to hook up when installing a brake controler both are under the hood. remove the fuse box cover and there are two studs at the front fuse box. there are two wires with eyelits criped on the them they are tapped to other wireing harness on each side of the fuse box. one wire is for the brake controler and the other is to charge the battery of your trailer it goes right back to the trailer plug. for that one you will have to intall a 40A fuse in the correct location in the fuse box. connect both wires to the correct stud and you will have no problem.
happy towing. as always if you have any concerns stop and ask you local dealer. they should be happy to help. |
07-24-2010, 12:02 AM | #4 | |
Son of a gun
Bill BEATERS ARE NEATER |
07-24-2010, 01:27 PM | #5 |
sorry i have no idea i just take them from the bolt bin at work and match them up. sorry.
08-03-2010, 08:40 PM | #6 |
Old member
Nice how to video!
http://www.etrailer.com/tv-Brake_Con...MC_Sierra.aspx
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
