Badass
bumper bolts
hey guys how can i stop the bolts un the bumper from stop spinning. i found a nice sport bumper in the junkyard last weekend and could get it off cus the bolts went out half way and then they spoon?
any way to stop this with out messing up the bumper?
Think outside the box? -84c10 (1stcar)→My Build← ![]() -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 ![]() |
Re: bumper bolts
If it's spinning cause it rounded out the bumper hole, or rounded off the square under the head of the bolt, then you can grab the head of the bolt with some vise grips to hold it.
Or - cut a slot in the end of the bolt and hold it with a screwdriver, in conjunction with an open end wrench. If it's spinning cause it simply is sticking out of the hole, then you can either (a) force it back into the hole by holding it with your hand or wedging a screwdriver under the nut to keep tension on it - or - b) if it is sticking out far enough then put a 1/2" (or appropriate size) open end wrench on the square under the head of the bolt. If its none of the above then just cut the bolt and be done with it. ![]() K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
The One And Only !!!
Re: bumper bolts
If you put vise grips on the head, Cut a slot in a piece of cardboard and slide it on the bolt shank. The cardboard will protect the bumper from scratches while using the v-grips.....
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! ![]() The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
![]() Join Date: Apr 2005
Re: bumper bolts
Good advice! Dead simple, but good advice!
#6 | |
Next project: 1970 K10
Re: bumper bolts
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
#9 | |
Re: bumper bolts
K
Slots go on anything!
Re: bumper bolts
The outers are the same, the inners are different.
1974 Jimmy- 5.3/4L80e/NP241 |
