Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 04-27-2010, 09:12 AM   #1
djracer
djracer's Avatar
How much cam is too much cam for power brakes
I'm talking about a 454 application this time but when is a cam too big to run power brakes without a vacuum canister?
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 04-27-2010, 02:11 PM   #2
Super73
Super73's Avatar
Re: How much cam is too much cam for power brakes
Not sure if this will help you or not but I was running a cam with 243/250 duration at .050 on a 108 intake center and a 111 lsa. I was able to run power brakes. But I only have 347cis..
I think the thing you need to look at is how much overlap the cam has and where the valve events are against static compression (leading to DCR). There is a lot that determines vacum at idle/cruise.
I'm assuming you will be running a hyd cam for maintenece reasons? Flat or roller? The lobe profiles will differ..
If you give me some more details I can put in it performance trends and give you an idea of vacum at idle. It may not be spot on, but might help a little.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 04-27-2010, 02:21 PM   #3
ripdog28
ripdog28's Avatar
Not sure but overlap and duration determine it. Roller cams, esp hyd i believe can take more then FT. not sure when you can not, all depends on the eng combo (Heads, carb)
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 04-27-2010, 02:20 PM   #4
djracer
djracer's Avatar
Its a lunati 60212.
Hydraulic roller, lopey idle. High performance street cam. Likes upgraded intake, carburetor and exhaust system. Needs 2800 RPM or better stall speed converter, 9.75:1 compression ratio and 3.55-3.73 rear gears.
Advertised Duration (Int/Exh): 282/290
Duration @ .050 (Int/Exh): 231/239
Gross Valve Lift (Int/Exh): .600/.600
LSA/ICL: 110/106
Valve Lash (Int/Exh): Hyd/Hyd
RPM Range: 2200-5800
Includes: Cam Only
Part Number: 60212
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 04-27-2010, 02:47 PM   #5
swb85
On a budget like Fred Sanford
swb85's Avatar
Originally Posted by djracer View Post
Its a lunati 60212.
LSA/ICL: 110/106
Includes: Cam Only
Part Number: 60212
You won't have any problems with that cam in a 454. I run a hyd 247/255 @ .050 in a 370ci and I have no problem with power brakes.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 04-27-2010, 02:32 PM   #6
djracer
djracer's Avatar
Heads are 781 oval ports with 2.19 1.88 valves. It should be around 10 to 1 comp.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 04-27-2010, 08:16 PM   #7
Super73
Super73's Avatar
Yeah, that cam is rather small for a 454ci in regards to idle vacum issues. You have 66* of overlap at .006 and 15* at .050..
In my 347 I have 24.5* at .050 and close to the same 66* you have at .006 with 107ci less..
Old 04-27-2010, 08:38 PM   #8
djracer
djracer's Avatar
Thanks Guys.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 04-28-2010, 12:25 AM   #9
Marv D
Registered Truck Offender
Marv D's Avatar
I agree with ripdog here Kevin, but keep in mind I don't know jack about the bigblocks and what is too much. That exhaust valve closing is going to be key in if it makes enough vacuum for PB or not. Could always advance the cam a little to get that exhaust closed a tad earlier and start building vacuum earlier too. Should help if it were marginal.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 04-28-2010, 12:34 PM   #10
shawnt
shawnt's Avatar
Good to go DJ. And that's a very good cam choice
Shawn
Shawn
85 SWB
7.39 @ 93
Best so far with 0 tuning
Lesson in life: Never fry bacon naked!
shawnt is offline   Reply With Quote
