Old 04-27-2010, 08:34 PM   #1
tcb-1
Nothing to see here.....
tcb-1's Avatar
Thumbs up Compressor "OFF" Switch? Thinking Outloud...
Gang,
has anyone installed something like a toggle switch to turn off the compressor when you start the engine? seems like the compressor draws a fair amount of voltage from the battery.
my compressor is set up to power up when the key is turned to "ignition on" or "accessories". when I start the engine, both the engine and the compressor compete for voltage and I'm draining my battery quicker than before.
I was thinking of putting an inline toggle switch on the "key-on" power line which I have connected to the fuse block.
any thoughts??
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 04-27-2010, 09:42 PM   #2
fixit-p
fixit-p's Avatar
Re: Compressor "OFF" Switch? Thinking Outloud...
Your starter is going to win that battle because it has the least resistance but if you want a simple interlock you could use a relay and interrupt the signal to the compressors relay, idk how you are currently wired but cut your signal wire to the compressor relay and connect one end to terminal 30 of the new relay the other end would go to terminal 87a which is normally closed, ground terminal 85 and connect 86 to the purple starter wire. That way anytime you engage the starter the circuit automatically opens.
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
Old 04-27-2010, 10:02 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
I'm with you on the toggle switch.
I don't like the compressor kicking on when I just have the key on.
I'm thinking about putting one on my blazer also.
Keith
Convert to disc brakes.
Old 04-27-2010, 10:21 PM   #4
gixxerpymp
I'm setting mine up the same way. Just seemed like the easiest way also.
gixxerpymp is offline   Reply With Quote
Old 04-27-2010, 10:33 PM   #5
texastrendz
i always let the compressor fully cycle before i tried starting the truck.
texastrendz is offline   Reply With Quote
Old 04-28-2010, 06:43 AM   #6
kev2809
low n' slo
kev2809's Avatar
I'm liking this toggle switch idea. all u would have to do is take the 12 volt wire from the pressure switch and wire it straight to the toggle, which is 1 wire to the battery and 1 wire ground right? also, this doesnt affect the pressure switch from doing its job since its still connected to the relay?
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 04-28-2010, 07:34 AM   #7
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
^^^^^ This is exactly what I did...I mounted the switch in the glove box...I also have a master switch for the toggles that work the air valves...you can dump the air shut off the switch and it works like a PARKING BRAKE...hard to steal something thats laying on the ground..even towing is out of the question!!
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 04-28-2010, 09:17 AM   #8
SCOTI
SCOTI's Avatar
I had comp/tank on my 68 for 5+ years wired to a 'ign on' power source. I can't remember 1 time where I turned the key & the comp came on @ the exact same time I was starting the truck??
Why are the air tanks below the air pressure cut-off? If there are no leaks, the tanks should be @ their pressure set-point unless you adjust the bag height before turning the key.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 04-28-2010, 09:51 AM   #9
Alvin
Never Done?
Alvin's Avatar
Just the thought of the leaks I'll have to track down when I get my truck back makes me cry. I am not looking forward to it.
Ethel - The Legend Continues...
Ethel has been sold.
Alvin is offline   Reply With Quote
Old 04-28-2010, 10:10 AM   #10
JWall
Frequent Flyer
JWall's Avatar
My truck had 2 shut off switches.
1 that shut off the compressors & 1 that shut off power to the valves.
That way you could lift or lower the truck without the compressors kicking on & also just incase some tried to bump a switch while at a show or something the valves were off (and also would work as a security precaution too)
- Justin
1 Owner 1976 SWB
Old 04-28-2010, 11:05 AM   #11
AVS_JASON
AIRBAGPARTS.COM
AVS_JASON's Avatar
Im with SCOTI. My comps don't turn on when I start the truck either. Takes a second or two after it starts for them to fire up. Was like that on all my trucks. But you can just throw a ON/OFF switch on the ground wire of your pressure switch. Super easy and cheap.
AVS_JASON is offline   Reply With Quote
Old 04-28-2010, 11:10 AM   #12
lyrikz
PITbut
lyrikz's Avatar
TCB,
I wired a switch in between my pressure switch. that way if i forget to turn it off, it will turn off itself.. In my walk around video of my truck in my signature you can see where i installed it...
that way i dont have both compressors running whenever they want to...
New project. 1971 Twin Turbo blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=676047
My new YOUTUBE channel.. Videos of my truck and a current walk around.
Lyrikz74 Youtube channel DONE! SOLD!
My 1971 stepside build thread
My Build Thread UPDATED 6/11. DONE
and sold.
lyrikz is offline   Reply With Quote
Old 04-28-2010, 05:28 PM   #13
kev2809
low n' slo
kev2809's Avatar
how do u make a toggle for the valves? run the switchbox power wire to a toggle?
-_--_--_ _________
Old 04-28-2010, 09:05 PM   #14
tcb-1
tcb-1's Avatar
wow, looks like I'm not the only one thinking about this.
kev,
I was thinking of putting a switch on the "key on" positive wire that feeds both the relay and the switchbox. I think that would work? **scratching head**
Doug
Old 04-28-2010, 09:10 PM   #15
Hottrucks
Hottrucks's Avatar
yea you two are on the right path I have one switch that is on the pos of the toggle switch feed and one on the relay for the compressor
you could make it so they where fed in the key on postion but if your somewhere and want to dump it your going to have to have the key on with just straight power the toggles will still work and the comp would stay off
Old 04-28-2010, 11:05 PM   #16
LEEVON
Moderator
LEEVON's Avatar
Hmmm, should be able to do this with another relay, it would be normally closed until it gets 12v signal from the key on position, opening the relay and killing power to your compressor.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
