04-28-2010, 12:22 PM | #1 |
Measuring Tailshaft?
I measured my Turbo 350 tranny tailshaft to see if it was 9" for my 700r4 swap. I measured from where it bolts to tranny to end of yolk. It is 9" between those two points. Did I measure it correctly? If so, the 700r4 is an easy swap with just moving the crossmember, Correct?
04-28-2010, 01:34 PM | #2 |
Re: Measuring Tailshaft?
no you didnt measure right// its from to the end of the casting ,yoke is additional
the original tailshafts in these trucks were all 6"tailshafts you need to move the crossmember and shorten driveshaft
04-28-2010, 03:39 PM | #3 |
Here is a picture showing the correct measurements.
Tim |
04-28-2010, 03:42 PM | #4 |
Thanks you very much. Mine is 6". Guess if I run the 700R4, I will have to have driveshaft shortened. Bummer.
04-28-2010, 03:44 PM | #5 |
Hey CDowns, If I run the 200-4R, I don't have to modify driveshaft, is that right?
04-28-2010, 04:12 PM | #6 |
no driveshaft mods required for the 224R just reposition crossmember
04-28-2010, 04:32 PM | #7 |
is your truck a long or short bed? I m having to cut my d/s 3". (longbed)It was cut previously for a long tailshaft 350.
1967custom |
