04-29-2010, 06:43 PM | #1 |
Heads and intake question.
I have a 73 350 block. im puting early 90s center bolt heads on it. I have the old edelbrock intake from the old heads can i make it work on the center bolt heads?
04-29-2010, 06:49 PM | #2 |
Resistance is Futile
Re: Heads and intake question.
This is a good question for the engine/drivetrain area, but I believe so. You may have to wallow the holes as the newer intakes bolt more in a vertical plane than the pre 86 engines.
I'm assuming as I know its possible to bolt a tune-port system on the earlier heads. I'm sure someone will correct me if I'm wrong.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
04-29-2010, 06:50 PM | #3 |
Blaze-Air
You'll need a new Vortec style intake I think.
04-30-2010, 12:28 AM | #4 |
60-66 Nut
He doesn't need a Vortec intake unless the heads are '96-2002 L31 Vortec heads.
To the OP. Yes you can use the early intake. You will need to elongate the center two holes on each side. Then you will need to either buy the wedge shaped washers or make them yourself. This is to give the bolt heads a flat surface to seat against.
