Old 04-29-2010, 10:43 PM   #1
texasfunk
texasfunk's Avatar
where does this wire go?? fuel pump not working
ok, so i went to start my 87, ran for a while, then nothing, i spent all day hunting down a parasitic draw and a short that was burning out my horn, after doing the test light thing and pulling the fuses i found the prob, now, the fuel pump wont turn on, could it have been something while pulling all the fuses? it also doesnt have a tank selector switch (hasnt for a while) and would this affect it after pulling everything? there is also a wire hanging off the fuel pump relay which i dont beleive has ever been hooked up, but with all the wire jumbling it very well could have been, i run it to hot and the pump turns on so the pump is good, any other ideas guys? im losing it on this one
2006 GMC Sierra CCSB, 6.0 swap
2000 Chevy C3500 Crew Cab shortbed dually
1999 Chevy c2500 Crew Cab shortbed
1982 El Camino 350/350
1979 K5 2wd blazer bagged/bodied
1986 Monte Carlo SS
1991 Chevy CK SWB-67 clip and tailgate, bagged 350/700r4
1955 Chevy Bel Air
2014 Chevy Silverado ccsb
texasfunk is offline   Reply With Quote
Old 04-29-2010, 10:46 PM   #2
texasfunk
texasfunk's Avatar
Re: where does this wire go?? fuel pump not working
and im sure it matters but i am no longer running tbi, it is a carb'd 355 and it doesnt have a mech pump
1986 Monte Carlo SS
1955 Chevy Bel Air
Old 04-29-2010, 10:59 PM   #3
JR0187
Does the relay kick on when you turn the switch on?
JR0187 is offline   Reply With Quote
Old 04-29-2010, 11:06 PM   #4
texasfunk
texasfunk's Avatar
no, it doesnt..and chevyrado, i figured thats what it was, cause as long as i have known it was unhooked, but when i ran it to hot it pumped fuel so it got me thinking...
1986 Monte Carlo SS
1955 Chevy Bel Air
Old 04-30-2010, 02:24 AM   #5
BIG V
that wire to the best of my knowledge is to test the relay. it connects to a hot lead to see if the relay or pump is bad... with out power no fuel pump working could be the relay or the pump add power to the wire if fuel pump starts working the relay is bad and the pump is good, add power and its still not pumping fuel pump bad..
BIG V is offline   Reply With Quote
Old 05-03-2010, 07:32 PM   #6
Desert1957
Desert1957's Avatar
Here is a link to this question a while back , Hope this helps....
Desert
http://67-72chevytrucks.com/vboard/s...d.php?t=355256
Desert1957 is offline   Reply With Quote
Old 04-29-2010, 11:04 PM   #7
78 Chevyrado
Not sure what it's for, but my 87 had the same wire, unhooked. when I checked the terminal with your same question, it looked like there had never been anything connected. It ran perfectly fine without it. It's likely an extra wire for some option your truck doesnt have, or it may be for troubleshooting.
78 Chevyrado is offline   Reply With Quote
Old 05-04-2010, 09:12 PM   #8
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
you will need a schematic. The wire hangin off is to test the pump.. maybe even the relay depending on what terminal its connected to. Remove the relay and take a look at it, see if it has a diagram on it. Usually it should, Theres 2 wires for the control side (power and ground) in order for the relay to do work. then theres the power and output. when the relays got both power and ground, and if its a good relay, the internals will click over and will connect a power wire (mentioned above) and the output together. That being said you can test that relay. A 9v battery will click the relay over once you determine the terminals to check. You know your pumps good since you manually tested it. Your problem lies between the ignition switch and relay. This is where the diagram come in handy. Without that... good luck... post up your findings
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
