low n' slo
![]() Join Date: Mar 2009
Extra port on my tank
hey guys. i was wondering what i should do with my extra port? i want to add a schraeder valve to it, or maybe a coupling for an air hose, or drain?
just wondering what i would get most use out of/and what everyone else is doing. thanks for any input! edit - forgot to add my tank is an 8 port tank. 4 for the valves, 1 on top for my tank gauge, 1 on the side for the pressure switch, and 1 on the other side for the compressor. bottom one is empty
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] Last edited by kev2809; 05-01-2010 at 08:52 PM. |
#2 | |
![]() Join Date: Apr 2005
Re: Extra port on my tank
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
low n' slo
didn't even think of that! I may run a t with a schraeder and coupler on the end...
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
![]() Join Date: Jul 2003
/raises hand. What would you use the shrader valve for?
If your compressor goes out, you could manually add air to your tank.....
low n' slo
beat me to it... so a drain port is not that important?
It'd be alot cooler if you did
I always just use the coupler to full the tank. I have a fitting that is male on both ends and just hook the air hose straight up to it if I need air while I'm working in the shop.
low n' slo
well I want the schroeder (sp) valve in case my compressor poops and I can fill my tank at a gas station or wherever.
I was browsing around ***************** and I'm having a hard time finding the right fittings lol. Ace didn't help at all, so I'm just gonna order them, I need airline anyways. what would I need to run a setup like harg robs, of course the cheapest easiest way possible!
low n' slo
I think I got it.....
I got 1 3/8" brass tee, 1/2" - 3/8" forged elbow (for tee to tank), and 2 1/4" - 3/8" reducing bushings (for schroeder valve and coupler).
I would put a drain in there too!!!
Redefining LowBudget
^^^ agreed %100
you would be surprized how much water these wil get in them from condinsation.... I put the drain in the bottom and put a 90* on the top with a piece of hoes running the a hole in the back of the frame that has a shrader and a snap fitting it makes it easy to fill and the location is easy if I have to use the air in the tank to fill something.....I use the same tech as Smashing Chuck when I'm around the shop working on it I plug into the shop compressor another good idea it s to use shut offs on each line if you have a line failure it doesn't blead off all the air in the tank (you can shut off the bad line) I didn't do this but when I fix the line I plan to add them for a few $$ its worth it ( ask me how I know??) I beleive that you can't have to many fail safes exspecially it it only cost a few $$
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
I have two 3 gallon tanks. I put a schrader on each tank, in the port that was point straight down for both the reasons mentioned here. drainage and compressor pooping out.
I also put a coupler on an extra port. but then when i got to thinking about it, it sure is going to be wild unhooking an air line with 175 psi in it. ![]() |
