Old 05-02-2010, 02:42 AM   #1
Zus1
Motor mounts for Big block 65 c10
Where can I find motor mounts for this application. I have read that it will be easier to move the engine forward.
Zus1 is offline   Reply With Quote
Old 05-02-2010, 01:13 PM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: Motor mounts for Big block 65 c10
The following threads should prove helpful:
http://67-72chevytrucks.com/vboard/s...g+block+mounts
http://67-72chevytrucks.com/vboard/s...light=bbc+swap
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 05-02-2010, 01:17 PM   #3
pctahlequah
pctahlequah's Avatar
I used a set of 67-71 BBC mounts I got on Ebay. They bolt in the factory location on our trucks. But a BBC is too close to the firewall there.
I've seen guys rework the firewall for for clearance, but on mine I moved the mounts about 3 inches forward to gain clearance for the valve covers and distributor.
'66 C20 converted to C10, 454/TH400
'66 C10 saved from crusher
pctahlequah is offline   Reply With Quote
Old 05-02-2010, 01:52 PM   #4
protrash64
Resistance is Futile
protrash64's Avatar
I used 73+ 1/2 ton mounts which center the engine between to the 2 factory positions. I ran stock valve covers and they fit with NO firewall hacking. Front clearance is a little tighter but workable.....2 header options depending on your clearance needs. Mine is running and driving, too. Check link in my sig.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 05-02-2010, 03:42 PM   #5
Zus1
Thanks alot guys. I read up on them and I'm sure i will have a few more questions like the headers. I want it to be as easy as possible. I think the electric fan should help with front clearance. HOPEFULLY!
Old 05-02-2010, 09:01 PM   #6
steverino66
My 454 is mounted on the forward frame holes with HEI dizzy, I used 71 towers/mounts/headers, plenty of frame clearance; short water pump gives plenty of front clearance with a fan. I did have to use a Groves components power steering pump mount.
I've heard 73-87 mounts/headers work well also.
steverino66 is offline   Reply With Quote
Old 05-03-2010, 12:02 AM   #7
Captainfab
60-66 Nut
The '73-'87 C20 frame brackets fit these older frames better than the C10 versions. On my Suburban I made my own frame brackets that moved the engine forward about 2 inches since I wanted to run my M/T valve covers. I used the '73-'87 headers also.
Old 05-03-2010, 06:46 PM   #8
protrash64
protrash64's Avatar
Here ya go.......perches, frame brackets, sometimes also called motor mounts..... they stradle the frame to the crossmember and the rubber bolts to the perch. These are 73+ 1/2 tons.
Old 05-04-2010, 12:22 PM   #9
markeb01
Senior Enthusiast
markeb01's Avatar
Here's the best thread available regarding disc brake parts options:
http://67-72chevytrucks.com/vboard/s...d.php?t=367260
