Old 05-02-2010, 10:11 PM   #1
truckin66
lowering springs
I recently installed 3 inch drop springs on the front of my 66. It did not lower it at all. Thier from classic performance products. Is there a better brand?
truckin66 is offline   Reply With Quote
Old 05-02-2010, 10:13 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: lowering springs
Sounds like your original springs were already sagged a lot so the new drop springs didn't net you any lower. Very common.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 05-02-2010, 10:41 PM   #3
64GMCHorsepower
Justified!
that sounds familiar, my original springs were sagging like Joan Rivers body....
Chad
1964 GMC Fleetside Shortbed....350/700R4 tranny
64GMCHorsepower is offline   Reply With Quote
Old 05-02-2010, 11:08 PM   #4
S-31
I bought the 3" front springs and 5" rears from cpp and they lowered my 63 about an inch in front and 5 1/2 in the rear. I was happy with the drop in the rear but not so much with the fronts, so i ended up taking them back out and cut one coil off and got it about 2 1/4 inches lower for a total of about 3 1/4 up front. If i had it to do over again i'd cut the original springs down in front starting with one coil and then about a half a coil at the time until i got it down where i wanted it, and save the money i spent on the front springs for something else.
S-31 is offline   Reply With Quote
Old 05-03-2010, 06:56 AM   #5
truckin66
The stock coils weren't sagging. I wish I had a pic of it to post.
Old 05-03-2010, 07:27 AM   #6
scooterskoolkustoms
scooterskoolkustoms's Avatar
I picture is worth a thousand words and you have no pic so lets have a couple thousand words of what they looked like?
big old burb in primer.lot of work to do.
scooterskoolkustoms is offline   Reply With Quote
Old 05-03-2010, 04:42 PM   #7
truckin66
well ive got 235/75/15 tires on it wich by no means are a short tire.Ive probably got 6-8 inches between the tire and fender well. from all the trucks ive seen on the web and in person it looks stock. It looks nothing like tx firefighter's truck. i have 4 inch drop springs for the back i have not installed because the truck is pretty much level right now. The rear would actually sit lower than the front.
Old 05-04-2010, 11:26 PM   #8
tapeworm
fan of "Butters" Stotch
tapeworm's Avatar
Unless the spings taken out were somewhat new, they were sagging
Are the springs properly seated in the pockets? It might be something to double check
64 shortbox fleetside
replacing rusty junk with more junk, and one day to become a real truck again
tapeworm is offline   Reply With Quote
