Old 05-03-2010, 11:22 AM   #1
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Chassis coating
What are you guys using and hows it holding up? Looking for something close to a factory semi gloss finish but need something durable. Will get driven alot.
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 05-03-2010, 12:01 PM   #2
SatisTraction
Re: Chassis coating
i used nason "chassis black" on my 69 camaro. it is a little glossy for me though. looks good and layed down easy.
WTB 73-87 SWB fleetside bed!!
85 C10 6.0 project
69 camaro ls1 / t56
90 mustang lx
75 bronco injected 351w
SatisTraction is offline   Reply With Quote
Old 05-03-2010, 12:11 PM   #3
Jonboy
Slots go on anything!
Re: Chassis coating
I am going to use catalyzed basecoat. Should hold up better than Krylon, and have a semi gloss look to it.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 05-03-2010, 03:30 PM   #4
nlped
nlped's Avatar
Re: Chassis coating
Look at this stuff. It seems to be right on time
www.nomorerust.com
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 05-03-2010, 07:35 PM   #5
SBTork
Garage wrench
SBTork's Avatar
Re: Chassis coating
I used a product called chassis saver....
http://www.magnetpaints.com/underbody.asp
I paid $35 or so for 1 quart of it and brushed it on myself, I think it came out really well. 1 quart did 2 coats on a regular cab shortbed two wheel drive frame. I used the antique/satin black. If you want I can take pics of the frame, it's still a bare frame in storage as I have put the project on hold for a while.
I also got a little spot on a pair of jeans that is still there from a year ago from the stuff.
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 05-03-2010, 10:18 PM   #6
STOCKISH
STOCKISH's Avatar
Re: Chassis coating
www.nomorerust.com
This is what I used the last time but was a little too glossy for my taste. Very durable though.
--Josh
Old 05-03-2010, 07:42 PM   #7
dammitmitchell
the pollock
dammitmitchell's Avatar
Re: Chassis coating
por-15
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 05-03-2010, 07:46 PM   #8
donut
donut's Avatar
Re: Chassis coating
What seems to have held up the best for me was SPI epoxy primer, it may be to flat for you though. I did different sections of my frame in different stuff. Hammerite on one section, needs to redone. Rustoleum on another section, but it's starting to show age. The SPI I used on the inner fenders and spring hangers and it seem to be holding up well.
I used Valspar "tractor" paint on the bed, but the jury is still out on it. (it's only been one winter)
I did mine about 2 years ago and I drive in the snow, slush.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 05-03-2010, 10:27 PM   #9
bigdnew
Never Satisfied
bigdnew's Avatar
Re: Chassis coating
tellin you go to john deere and get your hands on some blitz black.
1973 4x4 Blazer- Parting Out
1986 LWB Silverado Undergoing LQ4/4L80E Swap
'86 Build Thread:http://67-72chevytrucks.com/vboard/showthread.php?t=390566
bigdnew is offline   Reply With Quote
Old 05-03-2010, 10:59 PM   #10
twoodson
Re: Chassis coating
I used the por-15 chassis coat in the Satin Black for a factory look. I did the Marine Clean and Metal Ready process prior to applying two coats. I still have to do under the cab and the front part of the frame.
twoodson is offline   Reply With Quote
Old 05-03-2010, 11:25 PM   #11
asphaltburner
asphaltburner's Avatar
Re: Chassis coating
Yo! All my 40 and 35+ year old frames do just great kept clean with a bit of oil vapor and a light coat of dirt from frequent use! None of them need to be redone, and they aren't beautiful, but they're rust free!
Sorry, just had to be foolish and throw that one out to y'all. None of mine are for show, but they'll sure "road",...even the '42 JD B.
Todd.
'78 3/4 ton 4x4 custom "Todd-built" FRANKENTRUCK!
asphaltburner is offline   Reply With Quote
Old 05-04-2010, 08:08 AM   #12
James McClure
One shot, one kill.
Re: Chassis coating
I did mine with POR15 and then overcoated with gloss black enamel. It's still doing well after about 2 years. ALL the sheetmetal underneath and inside ALL the panels got bedliner spray and a 4" strip along the bottom edges all the way round got it too. I should have done the frame with bedliner too but never even thought to. Jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose.
James McClure is offline   Reply With Quote
Old 05-04-2010, 02:37 PM   #13
ECU PIRATE
ECU PIRATE's Avatar
Re: Chassis coating
I stripped it down to bare metal and used some self etching primer (2 coats) and some Rustoleum Satin Black (2 coats). Looks pretty good so far.
The Fleet........
68' Camaro - 1st car (restored & still have it)
09' VW Tiguan (Wife's Daily Driver)
14' VW Passat SE TSI (my personal)
14' Ford Edge Sport (Daily Work Vehicle)
73' SWB Stepside - 77K org. miles
74' LWB 454/TH400 - drive train transplant for my (Sold)
98' SWB C1500 W/T - shop truck (Sold)
90' GMC Sierra SLE short step - aka " Jezabelle " (Sold)
ECU PIRATE is offline   Reply With Quote
Old 05-04-2010, 04:54 PM   #14
79gmcc15
Gettin It One Pice At A Time
79gmcc15's Avatar
Re: Chassis coating
Is power coating to expensive compaired to the benefits?
RIP ELJAY
Work In Progress 1979 GMC C1500 Trailering Special.
Getting the truck done, one piece at a time.
“You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan
“I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby
79gmcc15 is offline   Reply With Quote
Old 05-04-2010, 10:08 PM   #15
85gmcguy
Plays with trucks
85gmcguy's Avatar
Re: Chassis coating
I've used Eastwood Chassis Black over their Rust Encapsulator. Goes on pretty easy and has held up for about 6 years so far without a problem.
Gary
My Dad's Old Truck
1985
85gmcguy is offline   Reply With Quote
Old 05-04-2010, 11:37 PM   #16
Fer79
Fer79's Avatar
Re: Chassis coating
kbs coating
Fer79 is offline   Reply With Quote
Old 05-06-2010, 12:21 PM   #17
jessecarosella
Re: Chassis coating
I have my frame sand blasted and semi glass powder coated. Very tuff on and off road!
jessecarosella is offline   Reply With Quote
