![]() Join Date: Jul 2009
forged or hyper
guys im building a 383. my engine guy seems like he wants me to use forged pistons. the ones he wants will put me around 9.5:1 cr and are 450 bucks. do i really need forged or could i go hyper. i dont plan on spraying it or FI
1972 SWB Medium Olive South Houston Instagram: Antbish84 |
On a budget like Fred Sanford
Re: forged or hyper
If no power adders are planned, hyper is just fine. In all reality, you can even put a light power adder (100 shot or ~5lbs of boost) to quality hyper pistons so long as the tune is in order.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD |
The Engine Whisperer
Re: forged or hyper
hypers can handle boost, just not spray. Remember the old GMC syclones and typhoons? I wanna say it was 11 or 13lbs from the factory on hypereutectic pistons. I know a guy here in cbus is a 5.0 mustang running hypers and 10lbs i wanna say he makes 435whp. So hypers can take boost, just not spray.
mini truck racer
Re: forged or hyper
Forged or cast for me .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
Re: forged or hyper
Tell that to all the ls1 cars that have a 150+ shot on them. Shoot there's some local guys around here that have been spraying 200 for several years on stock bottom ends.....they won't last forever, but if you keep it from detonating it won't grenade.
#6 | |
Re: forged or hyper
Re: forged or hyper
The one thing to keep in mind that it's relatively cheap now to go forged...but hella expensive later (new pistons, rebalance, etc.)
If you think in your wildest dreams that you might user a power-adder later...spend the $$ now. |
Re: forged or hyper
It wouldn't bother me to go hyper if no power adders. I had a ZZ4 that i angled milled the heads .020 put the comp hr282 cam in and 1.6 rockers drove it like i stole it and had close to 200 1/4 mile passes on it. always ran 91 or 110 in it the one time i put 87 in it it rattled but didn't hurt it. wish i still had that motor but that's how wheelin and dealin goes
2003 Dodge 2500 1969 C10 2014 Camaro SS/RS/1LE |
![]() Join Date: Jul 2007
Re: forged or hyper
Forged.
Registered Truck Offender
Re: forged or hyper
No way would I build ANY performance or even a towing engine with hypereutectic pistons. Add a little detonation and they turn back to the sand whence they came. I have opened up more than one broken motor and found a hypereutectic piston GONE, no evidence at all it ever existed. Well,, except the big gaping hole in the cylinder wall where the rod beat the crap out of it with no piston to guide it's path.
Hypers are great for a driver / cruiser. Little thermal expansion means they have a tighter bore cold, are quiet as cast, great oil control, no scuffing if the motor overheats. They have their good points. but they also have their down side.
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
Re: forged or hyper
I've built a bunch of hypereutectic engines - some that were pretty warm - and the only time I've seen 'em break is when more than a 75-100 shot of NOS is used, or when using Keith Black pistons without paying proper attention to ring gap.
NO engine is going to survive sustained detonation at speed... |
Re: forged or hyper
Okay I got the forged srp 18cc dished pistons for $ 450.00 out the door. I plan on running 72 cf heads which should put me around 9.1:1. This is with a 6.0 rod. At least this is what my engine guy is telling me.
1972 SWB Medium Olive South Houston Instagram: Antbish84 Last edited by POPO1984; 05-03-2010 at 10:07 PM. |
#13 | |
Re: forged or hyper
I'm sure the engine guy has "done the math" and done it right...but ask him to lay the whole thing out for you - deck height, head gaset, quench, etc. You'll want that stuff later for sure. Generally you want to collect EVERYTHING you can and put it in a "build book", which is the "bible" (<- not capitalized, so everyone relax ![]() |
motor exploder
Re: forged or hyper
Good call on the SRP's - I have a set of forged 23cc dome forged SRP's in my 468.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! |
#15 | |
![]() Join Date: Oct 2008
Re: forged or hyper
#16 |
Re: forged or hyper
forged, spend the extra money now.
#17 |
Re: forged or hyper
You made the right decision so now order that plate system to get that pig out of the hole! LOL
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
#18 |
Re: forged or hyper
That was one of the reasons that I got the forged. If I want to spray it way later down the road ill be able to.
#19 |
Re: forged or hyper
Who's building your engine popo?
#20 |
mini truck racer
Re: forged or hyper
#21 |
Re: forged or hyper
This older guy in South Houston his buisness is called speeco. Ive heard really good things about him. Really nice guy he is also doing my rebuild on the differential. His name is Harold or Buddy
1972 SWB Medium Olive South Houston Instagram: Antbish84 Last edited by POPO1984; 05-04-2010 at 01:10 PM. |
#22 |
Re: forged or hyper
If my memory serves me right someone on here had a 305 with a bunch of spray and I think it had cast or hypers in it but I wouldn't try it. I always say I would rather be lucky than good. That guy was lucky.
#23 |
Machinist
Re: forged or hyper
I have hypereutectics in mine... I have been spraying it with 200 for some time... Im not saying its a good thing. i will put forged in my next bullet. someone said "spot on set up" thats the key i dont see them being very forgiving when she goes lean or preignites. forged is the right choice
#24 |
Re: forged or hyper
local 135k mile STOCK Bottom end LT1 is running in the 9s (1/4 mile) on the hose so if you got the tune right, it will work....
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap |
#25 | |
mini truck racer
Re: forged or hyper
