Old 05-06-2010, 02:39 PM   #1
Rx79394
3 on tree bushings
I have a 3 on the tree and it has a lot of play in the shifter, I was looking at this faq here http://67-72chevytrucks.com/vboard/s...d.php?t=215307 and it says to inspect all 4 bushings, where are these bushings located at? Are they on those "ears"?
Rx79394 is offline   Reply With Quote
Old 05-06-2010, 09:09 PM   #2
Restrorob
The One And Only !!!
Restrorob's Avatar
Re: 3 on tree bushings
Yes, There's a bushing that goes in each of those ears which are the lower part of the steering column. The shift rods go into the bushings and the rods can wear as well so check them too.
You also have two bushings on the trans levers as well that the shift rods go into, Check them for wear too.
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
