05-06-2010, 03:57 PM | #1 |
Factory gear ratio's
I have done a search and could not find anything. I have a 1985 swb 2wd 10 bolt that came factory with a 5.0l 305. What did the factory offer for gear ratios? 2.73 or 3.08???????
05-06-2010, 04:07 PM | #2 |
Getting Old; Going Broke
Re: Factory gear ratio's
You should be able to use the RPO codes (in the glove box) and figure out what you have, as long as it has not been changed over the years. I believe most common is 3.42. RPO code is probably a G** one for your year model.
http://www.73-87.com/chevy_ids/rpo-eg.htm#rpo-g , easier way is to just link you. Has been a wonderful link for me decoding some stuff. Last edited by RandyP; 05-06-2010 at 04:15 PM. |
05-06-2010, 04:45 PM | #3 |
Parts and more parts
My guess on which ones was the most common would center around 3.08 gearing. There seems to a lot of those rear ends in the salvage yards.
Frank |
05-06-2010, 04:57 PM | #4 |
Should the codes on your truck tell you what you have? Only thing is I know the glove box in mine isn't original. Any other way to tell your gearing? Mine has a 12 bolt rear in it.
05-06-2010, 05:39 PM | #5 |
I have an 86 SWB with originally a 305 in it and it has 3.08's in the rear.
05-06-2010, 07:42 PM | #6 |
87 LWB, 305 and 3.08s.
It's slow. |
05-06-2010, 10:24 PM | #7 |
79 gmc factory 350.... 3.08's :[
Greg 1974 GMC 1/2 Ton SWB Fleetside L33 5.3/4l65e .................__
............._____l __\__ ..............l_(O)_ l___(O)] |
05-07-2010, 09:46 AM | #8 |
Thanks guys, it has the 3.08's. I ordered a set of 3.42's should help it.
05-07-2010, 11:25 AM | #9 | |
What transmission? tire size? That's a pretty expensive swap to not nail it exactly...
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
05-07-2010, 12:23 PM | #10 |
Slots go on anything!
a 700R4 will be spot on after that. The low 1st gear is better, too.
1974 Jimmy- 5.3/4L80e/NP241 |
05-07-2010, 12:35 PM | #11 | |
Conversion Truck Addicted
What would a C30 6.2 4 speed have 4.10?
dont have RPO cods or the tag on the rear end
Thomas Quote:
