Old 05-06-2010, 05:40 PM   #1
jyaughn
jyaughn's Avatar
front crossmember
will the front cross member out of a 64 chevy work on my 62? the reason im asking is cause my friend is givin me his 64 long bed
jyaughn is offline   Reply With Quote
Old 05-06-2010, 05:47 PM   #2
aggie91
I'm just glad to be here!
aggie91's Avatar
Re: front crossmember
I believe that the 62 is the torsion bar front suspension and the frame is wider. So NO, I do not believe it will work.
You could shorten the 64 frame and change our the hole frame, but that would be a lot of work and the cab & bed mounts might not be the same...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 05-06-2010, 07:21 PM   #3
KruizerKing91
KruizerKing91's Avatar
it will fit, the 4 of the the 6 holes along the bottom of the frame rails should line up. If your gonna go through that trouble though, you might as well get a 73-87 truck for 5 lug and disk brakes. its the same amount of work with more benefits. i picked up a 74 complete for 180 bucks and had the front crossmember bolted in under my 60 in just a couple late nights after work..
KruizerKing91 is offline   Reply With Quote
Old 05-06-2010, 07:55 PM   #4
Ghostwhite
Squarebody guy
Ghostwhite's Avatar
I absolutely do not wanna threadjack but is it worth keeping a 60-63 frame under a project truck? Overall goal is slammed.
Thanks a bunch
Ghostwhite is offline   Reply With Quote
Old 05-06-2010, 08:23 PM   #5
Slow Build
Slow Build's Avatar
Good place to get info on it.
http://67-72chevytrucks.com/vboard/s...d.php?t=366850
Sorry Mark. You must have been in the garage again (it's Mark's thread).
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 05-06-2010, 09:28 PM   #6
markeb01
Senior Enthusiast
markeb01's Avatar
Thanks a bunch
If slammed is of primary importance you'll be much happier in the long run getting rid of the torsion bar suspension. The problem being when the t-bars are unwound to drop the front, the adjusting arms under the cab hang down further and further the more it is lowered until they become an obstruction to safe driving. There's no reason to get rid of the entire frame however, just the 60-62 front suspension.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 05-07-2010, 06:44 AM   #7
Ghostwhite
Squarebody guy
Ghostwhite's Avatar
Thanks for the info guys.
I do plan on ditching all of the factory front suspension for later equipment or a porterbuilt member. I know it will fit, I have just debating the rear and the 63-66 seem more mod friendly with bolt-ons available where-as the 62 would require more straight custom suspension work.
Edit: I will formulate some good questions and dig up my old "build" thread for posting in. Thank you for your patience
