Old 05-07-2010, 01:27 AM   #1
jwalk
What was I thinking?
jwalk's Avatar
Rear dropmember with a stepside…
A few years ago, my grandpa gave me a truck that his father bought brand new in 1968. I was originally planning to use a short/wide bed, but I've recently decided I'd like to keep as much of the original truck as I can. However, it was a long/step and I'm considering cutting the bed down. My questions are: has anyone done this before? Are the long and short step fenders the same? Can I lay the frame down with a 285/35/22 with a step side (which I believe is a little taller than 29 inches using a rear 4 link bolt-on dropmember)?
jwalk is offline   Reply With Quote
Old 05-07-2010, 08:58 AM   #2
Shane
Shane's Avatar
Re: Rear dropmember with a stepside…
the step fenders are the same, the only difference was the step ... if the wheel you plan on running is much more than 8"-9" wide then you are going to have to do something in way of a mini-tub on the inside of the bed to keep from rubbing.
not alot of room under those cool stepside fenders once you air the bag out ... good luck and be sure to post pics
Shane is offline   Reply With Quote
Old 05-07-2010, 11:26 AM   #3
jwalk
jwalk's Avatar
Thanks Shane, I was wanting to run a 10" wide wheel. Not for sure if I can run a 10" with Nate's rear four link setup… The minitube probably won't be much of a big deal. I didn't know if I'd have to raise the fenders… I figured as far as cutting down the box, I'd cut 12" off the front, and 8" off the back. Does this sound correct?
Thanks,
Justin
Old 05-07-2010, 10:20 PM   #4
bigsnookmaster
bigsnookmaster's Avatar
I would cut twenty inches out of the middle. This way you only have one seam in the middle of the bed, and you cut some of that out when you add the wheelwells. You will have to fill and re-drill some fender mounting holes though. Ask me how I know? Good Luck!
bigsnookmaster is offline   Reply With Quote
Old 05-08-2010, 01:00 AM   #5
jwalk
jwalk's Avatar
How do you know? Just kidding! That does make alot of sense though. Just cut it all out of the middle.
Thanks,
Justin
I can't wait to get started on this project. It's been sitting for way to long.
