drop spindles
ok so i was looking in lmc and found some drop spindles for a 1/2 ton 2wd 69 chevy truck i have a 3/4 ton 2wd truck does anyone if these would work on my truck??
Re: drop spindles
I have the same question, I'm looking for some drop spindles for my 70 C20. From what I have read, the 1/2 ton ones wont work because of the ball joint size? I'm not sure if anybody makes drop spindles for a 3/4 Ton??
Josh |
Re: drop spindles
found 3/4 ton spindles on http://www.earlyclassic.com/catalog....ry=Drop%20Kits
Smoking Tires Since 1992 1969 c10 AKA SIN 1985 SSWB TRAZER (super short wheel base) |
Re: drop spindles
I was just looking at those, but it says they are conversion spindles? I dont want to convert to C10 stuff and want to keep my 8 lug.
It also says you can use your C20 tie rods and ball joints? So I assume that you can use them as C20 drop spindles and not convert to C10 stuff? My other question would be, what disk brakes do you use? The ones from a 72+ C20? Thanks and sorry to thread jack Jmal69 Josh Last edited by ranger2339; 05-10-2010 at 10:03 AM. |
Re: drop spindles
Im not really sure.
you could check out cpp for parts.
Re: drop spindles
Just called EC and they said no they wont work unless you use the C10 stuff.
Josh |
Re: drop spindles
thanks everyone for your input
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: drop spindles
www.PerformanceOnLine.com has them for the 3/4 ton trucks.
Look here: http://www.performanceonline.com/sto...at=1143&page=1
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 05-12-2010 at 08:38 PM. |
