05-10-2010, 12:35 PM | #1 |
how to determine what engine came in my truck
I just acquired a 1968 CST swb that had no engine in it. Unfortunately at one point the truck was repainted and the decal in the glove box was totally removed. Im trying to determine what engine the truck may have come with from the factory. Here is what I know:
It has the turbo 400 tranny. It did come with a v8 per the vin. It has factory air and power steering It is a non posi rear end. I mention these other items just incase one limits/narrows down the options. Id hope that it was a big block truck, but Im leaning towards the 327. Any where else I should look in the truck-any clues?? Thanks so much. |
05-10-2010, 01:05 PM | #2 | |
C-10 Club Member
Re: how to determine what engine came in my truck
In 1968, the 283 cu in (4.6 L) V8 was replaced with a 307 cu in (5 L) and a 310 hp (231 kW), 396 cu in (6.5 L) V8 was offered for the first time. Does it have sbc motor mounts? Maybe a different radiator for a 396? Pretty hard to tell without the spid. Turbo 400 makes me think 396 but that could have been added by a PO. Not to mention these trucks could be ordered any way you wanted back then. Congrats...post some pics
1969 Short Fleet 350/SM465 4.5/6.5 ECE drop 20" Raceline Wheels 1998 2dr Tahoe 5/7 drop 20"/22" Coys-sold Build thread...http://67-72chevytrucks.com/vboard/s...d.php?t=401910 |
05-10-2010, 06:50 PM | #3 |
So would the 396 in a C20 be different than a 396 in a C10? I thought my 396 L66 2 barrel was 265 hp
Blaine 59 GMC 9314 a.k.a. Whoopee 68 C20 50th Anniversary a.k.a. The Rat http://www.flickr.com/photos/northerngmc/ http://www.members.tripod.com/P-wee/index_032.htm 1.61803 is one H of a lot better than 3.14159, no really it is! |
05-10-2010, 07:21 PM | #4 |
High hump trans cover in floor bolts in for big block.BB cab will have heat sheild below ac box on lower firewall underhood or 2 holes where removed.BB mounts are shaped different but you can tell the difference at a glance.bb has about a 1'' diameter bolt hole in center and sb has 3/8 in center.
05-10-2010, 08:04 PM | #5 |
Check to see if the engine stands are still on the frame. If they are take a pic. BB look like these sort of but have a larger hole in the center where the mount mounts, like someome said.
72 Cheyenne Super 80 Silverado Blazer 2wd |
05-10-2010, 08:28 PM | #6 | |
72 Chevelle Club
I Have The Right To Remain Silent,But Lack The Ability 1972 Chevelle ... Mine 2006 Trailblazer... Hers 2002 Buick century ... Kids 2002 K1500 Z-71 EXT CAB ... Daily Driver 2005 Rockwood Roo ... For Camping 1974 Harley-Davidson XLH Sportster 84'' stroker |
05-10-2010, 01:09 PM | #7 |
Look for high hump cab floor, factory Exhaust hangers on both sides, were the engine mount stands left on the frame. These would give you some clues.
05-10-2010, 05:39 PM | #8 |
The frame mounts are still in the truck. What am I looking for?
05-10-2010, 05:45 PM | #9 |
resident oilfield trash
High up = big block
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada |
05-10-2010, 06:07 PM | #10 |
Maybe you should take the opportunity to put in what you want in. Our trucks aren't rare, make it what you want! ! !
72 Chevy C-10 Custom LWB 383 Stroker - Edlebrock Air Gap intake and 670 CFM Holley Street Avenger carb. Hooker Comp Headers w/ X-Pipe and 2.25 duals TKO-500 & 3.08:1 rear I Love HEMI's, they're soft & chewy! |
05-10-2010, 06:36 PM | #11 |
I know I can put whatever engine in it, but part of the fun of getting new stuff is figuring out what it is(was). What is meant between high up mounts? Any pictures.
05-10-2010, 07:04 PM | #12 |
Did you look for the build sheet? It should be under or behind the seat. It will be between the seat springs and the seat foam.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
05-10-2010, 08:37 PM | #13 | ||
"I ain't nobody, dork."
05-10-2010, 08:41 PM | #14 |
My SPID is missing as mentioned above
05-10-2010, 11:34 PM | #15 | ||
LOL... I went back to your OP and noticed that you had no SPID right after I posted. I "deleted" my post. You musta saw it before I did that...
Gary
05-10-2010, 09:15 PM | #16 |
307,327,or 396.The 396 had the dual exhaust and other mentioned items as well as a remote p/s reservoir mounted on the driver side fender.If it was a small block it will be hard to determine which.I`m trying to think of any differences in the engine compartment and coming up blank.I guess ithas the big radiator because of a/c?Maybe an a/c 307 didn`t?Never had one to know for sure.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 05-10-2010 at 09:19 PM. |
05-10-2010, 09:22 PM | #17 |
my 68 had a 283 in it.
DJ |
05-10-2010, 09:41 PM | #18 |
Thanks everyone. The mystery has been solved. I removed the carpet and the hump is non-removable. All signs point to small block which is fine for what I want to do with it. Now its on to buying parts...anyone have a complete set of side trim for a 68 cst swb?
