One of the First
![]() Join Date: Jan 2000
WTB-Shifter Parts / Standard Transmission
APP: SM 465 / 4x4 - I need the little square peice that fits at the end of the Z-Bar. It holds the shaft in place on the frame mount. Or If any one has a complete good working assembly - Z-Bar, both ball studs on each end/square retainer peice and push rod that goes from the clutch pedal to Z-Bar. I'll take a look at ...
Update: I've added some pictures. The square peice fits on the outer stud that is mounted in the groove on the frame bracket. Thanks
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) Last edited by D.PASSMORE; 05-13-2010 at 08:47 PM. |
![]() Join Date: May 2007
Re: WTB-Shifter Parts / Standard Transmission
what year,I believe there are two different styles.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
#3 | |
![]() Join Date: Sep 2009
Always appreciate you Paul
You can shear a sheep every year, but you can only skin it once The person dealing with facts is never at the mercy of the person dealing with theory 1972 Cheyenne Super 402 400 A/c bucket seat tilt custom camper Longhorn 1975 Silverado 454 Crew cab camper special dually |
One of the First
Its going on my '72 Blazer. I can't find the little square peice at the end (frame side)... Anyway, I believe the Z-bars are different on 2wd and 4 wd and 4 SP top loader compared to a column 3 SP. I might take pictures and post for clarity. Any other comments would be welcome.
![]() Join Date: Sep 2007
this is from a 67 2wd with a 3 speed and granny gear, floor shift. probably NOT what you need
1967custom |
I have a 69 4x4 burb with smblk 465 that has the complete set up,I'll try to get pic when it safe to go out side( poring rain )
One of the First
Sounds good!
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) Last edited by D.PASSMORE; 05-12-2010 at 10:20 PM. |
One of the First
Yeah, that is on the frame. I need the square peice that fits on the end of the outside z-bar/ball stud, which fits in the groove and holds the complete Z-bar assy in place.
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
One of the First
Ttt
I think the part you are looking for is missing from this set up also
#11 | |
One of the First
I re-installed mine a few months ago and after seeing your post I had to go check and see how I did installed it. Maybe I better look for one too! I remembered that mine didn't have it when I took it apart, so that's how I put it back together. Maybe it's on that "don't forget to check before driving" list I have around here!?
--------------------------------------------------------- I'm not crazy, I'm chosen, there's a difference. ---------------------------- '72 K10 SWB, 350, sm465/np205 ---- ---- |
One of the First
Good news, I found the peice. It was at the bottom of my shop garbage can. My son picked through the garbage before he changed liners and found it. Know idea how it got in there! Anyway, I'll post a picture of it. Thanks
#15 |
Excellent! So can you ask him check the other cans! I need one!
