Polly bushing's squeek
Last year I put in a set of polly bushings in my A-arms and just the other day they started squeeking, every stinking bump, squeek, squeek, squeek, well you get the picture. Is there a good fix for this other than just spraying something all over them that will collect dust and grime?
Re: Polly bushing's squeek
grease,got zerks?
no grease zerks.
I would take them apart and drill and tap for zerks but that's me .
#5 | |
Replace them with poly-graphite bushings
1965 GMC shortwide big window 1969 Chevy C20 long (for now) 2005 Silverado 2500HD Crew Cab Quote:
I dont think the metal is thick enough to add a zerk, and I'm not to keen on replacing the bushings, I thought the bushings that I got were suppose to be "Squeek Free". I have done alot of work to this truck and really am getting burnt out on it.
what are zerks
#9 | |
Seriously, when I replaced mine, they squeeked for a while. But, eventually, they quit squeeking. Unless you take them back apart and coat them with some sort of grease, you'll probably have to live with it for a little while.
Chris 1966 Chevy C10 LWB, 434 sbc, TH350, 12-bolt, factory suspension, pump gas 7.02 @ 95.8, 1.45 60' 1965 Chevy C10 LWB, 355 sbc, TH350, daily driver |
i used poly control arm bushings on a pathfinder i had and they squeaked until the day i sold it...and likely still are but at least i don't have to listen to it anymore. I always cranked up the tunes.
LOL, that is proabably the only reason I heard the squeek, I had the radio turned down the other day and that was when I heard it for the first time.
Watch out for your cornhole !
![]() Join Date: Jun 2003
Every bushing in my truck is poly, front control arms, sway bar, rear trailing arms, even cab mounts. It is awful. The squeaking and harshness completely remove all enjoyment of driving the truck. Take my advise everyone, go rubber.
I re-did all the bushings in my Corvette with poly. It handles better, rides about the same..... And squeaks..... going on 15,000 miles now.
1964 Chevy Short Fleet: Tornado 1972 Chevy C10: Fast Orange Secondaries Wide Open |
#14 | |
Rollin' Old Skool
i wondered about this when looking through your build thread, since i had read some other posts about the poly/rubber debate...my suspension overhaul will be very similar to yours...from reading a few other posts, i had already planned to go rubber when i change everything to 5-lug, but it's great to have your advice! |
#15 |
and a few others
One temporary fix would be to go to NAPA (it's not sold at Advance or Auto Zone type places) and buy Ru-Glyde. Spray it on your bushings every couple weeks or so. It won't collect dust, and it's a rubber/poly lube.
Bill ![]() BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
