05-16-2010, 01:25 AM | #1 |
im getting tired of this...
so my luck is terrible.. my tranny started leaking a while back. first just a drop or two then puddles.. so i changed the trans pan gasket and filter and rear output shaft.. twice. still leaked. turns out the tcs sensor or something like that was broke and leaking too. i got it plugged and everything was fine and dandy.. for about a week till i looked under my truck this morning and saw a 3x3 foot puddle of tranny fluid in my driveway... the fluids coming out of the end of the yoke.. ive never seen a leak like this before.. the u-joint is covered in fluid and the fluid is just running out of the center of the yoke going into the tailstock.. does anyone know how to fix this so i can get this rig back on the road? whatever i need to buy/do and if its deep or just a quick fix? thanks in advance guys
"I'll keep my guns, money, and freedom. You can keep the "change" |
05-16-2010, 02:08 AM | #2 |
Re: im getting tired of this...
The best most permanent fix is to pull the yoke. remove it from the driveshaft and weld the hole shut. i think theres an o ring on the tail shaft with that style yoke. its a small hole just weld it shut.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
05-16-2010, 08:30 AM | #3 | |
I'm pretty sure that the hole is there for a reason. It allows the yoke to slip on the tail shaft with out greating pressure or vacuum as the space inside grows/shrinks during it's travel.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
05-16-2010, 09:23 AM | #4 |
http://www.73-87.com/7387garage/drivetrain/yokeleak.htm
Awesome write up on this. |
05-16-2010, 04:25 PM | #5 |
I have acouple driveshafts layingaround.. Will itreally hurt anything if I weld it up for now until I feel liketearing the tailstock off to change the seal? I need itfor a dd for a few more weeks before I'm building the motor. Ill problychange that thentoo.
05-16-2010, 04:40 PM | #6 |
A lot of yokes dont have it though. And I have never seen an issue with the ones that dont have the yoke with the hole in it. Is this a 2 piece or 1 piece driveshaft? Does it have a slip yoke on the back part of the shaft? If its a 2 piece shaft with carrier bearing. The yoke cannot move in or out of the transmission anyhow so pressure buildup wouldnt be an issue.
05-16-2010, 09:36 PM | #7 |
it dont have a slip yoke on the back part. only going into the trans of course.. its a long bedwith a one peice. o ya its 2wd. i took it out and welded it up, and it stopped leaking. i found a rebuilt th350 with a ****f kit and a stall convertor with the lockout torque for 500 bucks.. its a co-workers so ill probly snatch that up when i get my vortec build done with.. but is it or is it not bad on the trans like this? everything seemed fine when i drove it..
05-18-2010, 09:23 PM | #8 |
i was told to jb weld mine shut. that was 10000 miles ago
05-18-2010, 09:47 PM | #9 |
good to know... i just got a welding rod down the center of the yoke and welded her shut. stopped leaking but i wasnt sure if it would hurt. good to know it wont hurt
