Old 05-16-2010, 06:38 PM   #1
67 DREAMING
rearend gear swap
ok guys i really need some advice on a lower gear for my 91 k1500. had transmission rebuilt with heavyduty servos (700 r4) just had engine rebuilt board 30 over with flat tappet cam 290duration with a 298 lift and i caint feel any diffrence while im pullin my airboat granted an airboat has its share of wind resistance but were only talkin maybe a 1500 pound with trailer and all now i am runnin 15x10 wheels with 35x12.50 mud tires would a 4.10 gear ratio 4.11 be where i get my best peformance any ideas or advice?
67 DREAMING is offline   Reply With Quote
Old 05-16-2010, 11:09 PM   #2
Critter
Future TOTM Winner
Critter's Avatar
Re: rearend gear swap
Personally, I would say you need at least 4.56s with that setup if you are pulling.
I look here whenever I am trying to determine gearing. For everyday driving you probably want your RPMs at highway speeds to be around 2000 in overdrive. Although you shouldn't be pulling in OD with that tranny. Another thing to keep in mind when using a gearing calculator is that your actual tire height is likely different than what is stamped on the tire. For a 35x12.5 I usually put in a tire size of 34 inches. Hope this helps a little.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 05-17-2010, 10:15 AM   #3
Burt4x4
Burt4x4's Avatar
I agree, with that auto & 35s 4.56 is were you will 'feel' a difference. If you get 4.10s you'll allways be wondering what 4.56s would have been like.
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 05-17-2010, 09:15 PM   #4
martindc1
First what is your current gear ratio?
Currently truckless, previous trucks:
67 K20, 87 K10 aka V10 & 72 C10
martindc1 is offline   Reply With Quote
Old 05-18-2010, 07:53 PM   #5
Mike C
Mike C's Avatar
Are you going to pull in OD, or in third? Please post more cam specs. The lift # at the cam? The duration advertised at .001 or somewhere else? What is the .050 duration (best # to compare cams IMO)?
If you have 3.42's now and the cam is 230+ degrees at .050 you aren't going to have any power. You need a cam with 210-215 degrees at .050 max IMO. 3.42 and 35" tires are OK with no OD, but in OD and pulling a trailer you have missed the curve completely. If you currently have 3.73, pulling in 3rd shouldn't be so bad.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 05-18-2010, 08:49 PM   #6
chas350
x2 on the cam...
"I'll Procrastinate Tomorrow"
quote by LEEVON
71 K10 long fleet (sons truck) new 370hp 355, sm465 np205, 3.73's 33's
70 K20 long fleet
98 G3500 work van
chas350 is offline   Reply With Quote
