05-17-2010, 11:59 AM | #1 |
Back to the 1987
Well,
I kind of put this truck on hold after losing my son in a car accident on Halloween. Now I've started working on it again. How to begin. Let's see. I've changed almost every sensor on this engine and have it running o.k.. It still hesitates a little, more so when it's warmed up. But the main issue is when coming to a stop sign it will sometimes die and will not restart. Really troublesome but I found, not sure how, that when I unhook the battery for 10 seconds and then reconnect, it will start right up. It seems to me for whatever reasons the computer is not letting the fuel pump run and when it's reset, it works fine. Any direction? |
05-17-2010, 12:03 PM | #2 |
Re: Back to the 1987
sorry for your loss. check how much psi is getting to the fuel pump should be getting around 12 psi.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 Last edited by Matt Man; 05-17-2010 at 12:04 PM. |
05-17-2010, 01:05 PM | #3 |
Thank you, and I will check that.
05-17-2010, 11:24 PM | #4 |
Try changing the module under the distributor cap...It happened to me before and it was an easy fix...You can get one from your local parts store...
05-18-2010, 05:55 AM | #5 |
BAD BOW-Silverado XST
Have you checked the engine codes? Bookmark this website: http://www.cfm-tech.com/GM_tbi_tuning_tips.htm
You can power tune the TBI. .... |
