05-19-2010, 09:35 PM | #1 |
Rear end seals!!!
the rear end in my 85is out of an 84 burban 2wd. its a 5 lug ten bolt. it has alot bigger brakes then the ones that i took off my 85 so i dont know if this makes it a 3/4 or what? i thought it would have to be a 6 lug for that.. anyways, the rear end sprung a leak at the pinion gear? where the driveshaft goes in.. can someone tell me exactally what seal to use and how to do it? i went to my local parts store and there was a few different seals.. i dont wank to tear it down and have the wrong one.. also how much fluid am i gonna need? thanks guys!
"I'll keep my guns, money, and freedom. You can keep the "change" |
05-19-2010, 11:09 PM | #2 |
Re: Rear end seals!!!
nothing?
05-20-2010, 07:25 AM | #3 |
If it's 5 lug then it's 1/2 ton 2wd.
6 lug is 1/2 ton 4wd. It would be 8 lug in order to be 3/4 ton. I can't tell you which seal you will need, but you'll need to pull the rear end completely down in order to replace it. If there are shims on either side of the differential ring gear carrier, make sure you note how they came out so you can put them in the same way. And - make sure someone gives you some pointers on putting the pinion gear back in correctly (as far as rotating torque, squishing the crush sleeve, etc). It's not hard but you have to know what you are doing. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 05-20-2010 at 07:25 AM. |
05-20-2010, 07:44 AM | #4 |
Getting Old; Going Broke
Mine was leaking badly out of the pinion. Just take the driveshaft off and put a pinion seal in, was fairly easy to do actually. Drain all the fluid first in the third member.
05-20-2010, 06:20 PM | #5 |
thats where mines leaking.. just wanted to know how big the job is or if id need any special tools before i tore it apart and couldnt get it back together for work lol
05-20-2010, 08:16 PM | #6 |
Yea...same here. This must be a common occurence with 10-bolts. I've had several 14-bolt full floats that have almost 200k miles and never leaked at the pinion. My 10-bolt has less then a 100k and it's leaking pretty badly now in the exact same spot.
I'd be interested in how hard it is to change the seal. I'm heavily considering just swapping the rear out completely with something stronger...like a 12-bolt or 14-bolt sf. Not to mention correcting the crummy front/rear tract width difference. Last edited by stkcode; 05-20-2010 at 08:33 PM. |
