Old 05-19-2010, 10:07 PM   #1
BlazerBoy
Question 71 Blazer 4x4 stock 350 , T350 , NP205 want to swap in Vortec 7400 (454) Questions...
Ok i have a 71 Blazer 4x4 stock 350 , T350 , NP205 want to swap in Vortec 7400 (454), Asc far as i know and what i have read the 454 will bolt to the T350 fine .. ? right ? haha thats my only concern at the moment because i believe the mounts and everything should be about the same since Vortec or not its just a revised 454. And i know that the suburbans came with a 454 and i believe had a T350 behind them, I may upgrade the trans later but i just want to know if i will have any Bolt up issues taking out the stock 5.7 350 and replacing it with the 454. Thank you for your time in advance
1971 Blazer K5
1987 Suzuki Samurai
2002 BMW M3
Parts
www.Line-X.com
www.Brotherstrucks.com
www.LMCtruck.com
www.TruckAndCarShop.com
www.TruckManPartsInc.com
BlazerBoy is offline   Reply With Quote
Old 05-20-2010, 01:53 PM   #2
Brandoneh
Re: 71 Blazer 4x4 stock 350 , T350 , NP205 want to swap in Vortec 7400 (454) Question
Your 454 will bolt the th350 just fine. I would look into a diy4x motor mount and tell him your running a big block. Kert will hook you up with a motor mount that will raise the motor a little to clear that crossmember. Your also probably looking a little firewall hacking. The blazer doesn't have room for the big block so your going to need to make room! a body lift helps.
Hope that helps.
71 K5 In progress!
Brandoneh is offline   Reply With Quote
Old 05-20-2010, 03:57 PM   #3
BlazerBoy
Hope that helps.
Ahh thank you for the input and after all night if looking things up and cost effectiveness And what not I think i will just go with the Vortec 5700 since i prob dont need all that massive power and weight right now, It was a idea but i think i will be just fine with the Vortec 5700 (350) it should do everything i want it to do haha and have Fuel Injection
1971 Blazer K5
1987 Suzuki Samurai
2002 BMW M3
Parts
www.Line-X.com
www.LMCtruck.com
