05-21-2010, 06:46 AM | #1 |
Aftermarket A/C ...Where's your alternator?
I am about to order A/C either from Old Air or CAA. I am curious to where people are relocating their alternators and what brackets they are using.
I want to stick with the long water pump and my alternator is currently on the passenger side. i would like it high on the drivers side, but the only brackets i have found are for short pumps. I have seen the low/mid mount bracekts, but I am wondering if that is going to get my alt wet when i hit puddles. Last edited by dznucks; 05-21-2010 at 06:46 AM. |
05-21-2010, 10:07 AM | #2 |
Re: Aftermarket A/C ...Where's your alternator?
I have Vintage Air in my 70 Truck and the alternator is in the stock position ( high on drivers side). The a/c unit is high on passenger side. You might want to check with alan grove for the brackets you want for your particular location of installation.
05-21-2010, 10:23 AM | #3 |
Spanked once
Drivers side on my 55 and 71.
Old air brackets on the 55 and http://www.hotrodsusa.com/store/bills.html on the 71. I like Bills better.
The ole 350 budget build. |
05-21-2010, 10:36 AM | #4 |
also did vin air. moved alt to driver side and a/c on pass side. Did not want a/c hoses going across motor. also used alan grove brackets. simple bolt on. I am sure he has them where ever you want to put alt/ac. Gary
05-21-2010, 02:35 PM | #5 |
Cool, thanks guys.
does anyone have pics of their setup? I'll check these suggestions out. I didnt want my A/C line crossing the engine either. |
05-21-2010, 02:39 PM | #6 |
I have classic auto air in mine...here are some picts....
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
05-22-2010, 08:18 AM | #7 |
Interseting thread. I too have been perusing which aftermarket AC system I would go with too...planned for next spring.
I will be going with the Old Air system to use on my BB. Both OA and VA suggested I move the alternator to the driver's side and buy the optional bracket. This makes alot of sense. Getting the compressor under there, although looks to be a very nice and clean looking install, seems like it would be much more difficult either from the top, under the alternator, or from underneath the vehicle during install or when maintenance is required. I went with the OA syatem because the electronic servo control unit is very appealing. No cable adjustments and seems to be easier to work on if need be.
John Paap Ole Greenie Hagerstown, MD My Mistress 70 CST Short/Step LS 5.3/4L65E New motor install Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=667773 |
05-22-2010, 09:33 AM | #8 | |
they allow you to use the factory "heater" control. not the A/C controller. Unless i read it wrong. |
05-22-2010, 09:47 AM | #9 |
i was mistaken, i found the kit that allows you to use the original A/C controller.
05-22-2010, 11:04 AM | #10 |
WORTHLESS CRUISERS
I have installed both OA and CAA in several trucks and cars. CAA allows you to use factory heater controls. CAA also looks neater and built very well. Both companys sell brackets for any install(A/C and Alt). Good Luck
Scott Hammond Lancaster, SC 1969 Chevy2005 Chevy Silverado Z71 72 Chevy 1972 SWB 454 If you don't live for something, then you'll die for nothing. www.xclusive-images.com |
05-26-2010, 08:17 AM | #11 |
Does anyone know of a drivers side, low or mid mount alternator bracket that can be used with a long water pump?
