Old 05-21-2010, 08:03 PM   #1
jessewebb
jessewebb's Avatar
changing ring and pinion
Hi, I have a 69 C/10 it has a 72, 12bolt 307 rearend. I want to change the ring and pinion to a 373. My question is, Do I need to change anything else. I seen a 373 0n ebay, but the guy says if you have a 307 carrier it wont work. i also need a 373 carrier. Any help would be appreaciated. Also I'm not deadset on the 373, I could use alil advise on the rearend size also. I have a 350 with a 350 auto, it's just dead on take off. around 60 or 70 when i punch it, it does very well. it sounds like a beast, but i need 15 mile straight to wound it out.
jessewebb is offline   Reply With Quote
Old 05-21-2010, 10:43 PM   #2
low'n slow
Too Dumb To Know Better
low'n slow's Avatar
Re: changing ring and pinion
you will need a different carrier.
low'n slow is offline   Reply With Quote
Old 05-22-2010, 12:04 AM   #3
capev86
put in an overdrive trans with that 3.73...200-4r is a bolt in for a turbo 350. the effective top gear ratio will be around 2.61. that means you will have awesome highway cruising AND better get up and go. a lockup converter is another good idea....save every last rev and reduce trans temps.
my dad swapped his 87 burb 2wd over from a 3.08 to a 3.73. it already had OD and so he "maybe" lost 1mpg. the weight, aerodynamics combined with new england hills may have been too much for that soft rear gear to handle. it still pulls of 18mpg. i say...have your cake and eat it too!
capev86 is offline   Reply With Quote
Old 05-22-2010, 07:14 PM   #4
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Do you have the special tools to do this job? If you dont, dont mess with it. It may look easy but rear diffs are the one place you dont want to experiment with, or you will be setting on the road waiting for a tow......Also 3.73 with that drive train combo will be real bad on gas. Turning high RPMS at 60/70 MPH.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 05-22-2010, 09:18 PM   #5
jessewebb
jessewebb's Avatar
Thanks friends for taking the time to give me some input. I'm shopping around for the carrier and gears. I'm goin with the posi 373. Not really gonna drive anywhere but around town, gas mileage not a concern, unless it goes to $5 again. Smitty you have a sweet lookin truck, and the low'n slow truck is a looker too. I hope to post some pics of my 69 when I figure out how to do it. Thanks again
Old 05-23-2010, 11:05 AM   #6
71meangreenc10
Thanks Jesse,
Smitty
71 C30 Wrecker
