Old 05-22-2010, 09:13 PM   #1
Slow Build
Slow Build's Avatar
Oil change question. (capacity)
In the middle of changing my oil. I have a 283 casting # says it 1957-66.
What is the oil capacity. I would have thought 5 quarts including filter. So far I've put in 5 quarts plus a bottle of Bars leak and it's barely touching the dipstick (probably 2 quarts low). I'm starting to question the Mr Gasket oil dipstick that the PO put on it. Maybe that's why the engine leaks oil (overfilled). The oil pan doesn't look like an extra capacity unit. It has the drain plug on the front of bottom of the pan.
I'm not sure what to do at this point.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 05-22-2010, 09:17 PM   #2
Rich 5150 69
Rich 5150 69's Avatar
Re: Oil change question. (capacity)
If its a standard chevy oil pan its 5 quarts. I`d say wrong dip stick....!
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 05-22-2010, 09:20 PM   #3
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Arrow Re: Oil change question. (capacity)
With a stock oil pan 4 quarts.
1 quart canster filter.
So yes total of 5 quarts.
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 05-22-2010, 09:26 PM   #4
Rich 5150 69
Sounds as if somebody has put the lower dip stick tube above the block....??
Old 05-22-2010, 10:03 PM   #5
Slow Build
Slow Build's Avatar
That's what I'm thinking. Guess that's why it blew the oil filler cap off and nicely coated my engine compartment.
Past GM Trucks:
Old 05-22-2010, 10:09 PM   #6
Rich 5150 69
Ok...... oil dip stick comparison anti up guys, my bayonet cap is even with my valve cove base....
Old 05-22-2010, 11:35 PM   #7
Slow Build
Slow Build's Avatar
Mine is higher and noticeably dirtier (but don't worry it's not longer) . Is that a Mr. Gasket stick?
Past GM Trucks:
