Location of all Zerk fittings?
My poor 72 squeaks like crazy. You can definitely hear it coming before you see it. My Haynes manual doesn't clearly list the location of all of the Zerk fittings. Can someone out there tell me where and how many I should be looking for? Thanks.
1972 Chevy C-10 ~ 188,000 miles give or take |
Cruzin
Re: Location of all Zerk fittings?
upper and lower ball joints, tie rod ends, idler arm all i can think of at the moment
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
#3 | |||
Union Electrician
Upper and Lower control arms, drive shaft
![]() ![]() Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
changing out my body bushings and putting in new leaf springs helped quiet my truck down alot.
1970 GMC- 454 DONT GIVE ME NO JIBBA JABBA!!! |
Redefining LowBudget
dont forget your U joints
also spray a bit of white grease on the front of the trailing arms,might as well do your hindges too.....
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
This is an old pic that I had saved, this was listed for 70 and later models. Hope it helps
Erik 1967 K10 SWB Big Window - Bone Stock 1955 JEEP CJ5 13K orig miles (Resto waiting patiently in the garage) |
Restoration Virgin!
if you put new sway bar brackets on there's a couple there too
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
As previously mentioned, check your swaybar bushings if you've got one. Mine squeaked like crazy until I put some new bushings in.
#9 | |
![]() Join Date: Sep 2009
Hope that helps Paul and Jason
You can shear a sheep every year, but you can only skin it once The person dealing with facts is never at the mercy of the person dealing with theory 1972 Cheyenne Super 402 400 A/c bucket seat tilt custom camper Longhorn 1975 Silverado 454 Crew cab camper special dually |
#10 | |
Restoration Virgin!
Don't forget the clutch linkage z-bar.
![]() Join Date: Apr 2016
This is the top search hit for location of all zerk fittings, so I would like to revive it please. I have this same question for my 1969 CST/10. I have not found even 1 zerk fitting anywhere on the truck. I believe the previous owner may have had all of the zerks removed. If found a couple places where there is a hole and perhaps there were zerk fittings. I'm finding it hard to believe the truck would have had no zerks at all from the factory and only replacement parts have zerk fittings, but perhaps that is the case. Is there a diagram or map to where all the zerk fittings are supposed to be for a stock truck? Diagrams or pictures are really desirable because I don't know the names of all the parts, being a suspension and steering newbie.
Its time to get a service manual
Yes, thanks, I have one. It is not very good for this. Here is what little diagram there is. It would be quite nice if somebody could take pictures of their truck in the various positions where the zerks are installed, and number the pics according to the diagram. This thread would turn in to pretty good documentation.
#15 | ||
"I ain't nobody, dork."
That diagram you put up is perfect. It tells you what the part is called and also the general area to find them. They are not that difficult to find to be honest. Crawl under there and start looking, it's what we did prior to the internet.
![]() ![]() Gary
#16 |
What's a zerk fitting? Do you mean alamites?
![]() If you don't know where the zerks are and don't have a road map, just look at all the areas under the truck that spin or pivot, or just think about what would need lubrication that isn't inside a case, like engine, transmission, transfer case, axles, or steering box. In other words, anything that takes fluid lube. Driveshafts spin, front ends turn, and bell cranks... crank. < There's one people often overlook. They need lubrication.
#17 |
![]() Join Date: Feb 2009
18 zerk fittings on my 71 C-10 counting the drive shaft.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#18 |
Thanks all, I am finding them and learning the part names. There are zerks missing but there are holes, so I will get a zerk multitool and some zerks and install.
Questions: I have found no evidence of a zerk or hole for one, and also no large boot for grease at these places. Is that normal, or am I just not finding it? 1. Pitman arm to center link pivot 2. Idler arm to center link pivot 3. Idler arm to idler arm support pivot Is there a bell crank somewhere on the truck? In the illustration and chart above where it says "Intermediate Steering Shaft (PA10)" does the PA10 mean some other type of vehicle, not a C10 so I don't need to worry about that one? |
#19 |
Manual shift trucks have a bell crank... frame to ball stud on block.
#20 |
![]() Join Date: Dec 2015
Newbie question, I didn't see where on the steering shaft or steering gear that I need to hit, on my '68 that has power steering.
1968 Long Bed 2016 Honda Civic Coupe EX-T ticket magnet |
#21 |
I am back with pictures of zerks numbered according to the manual page above in post #14.
Upper control arm and ball joint, driver side Lower control arm front and tie rod ends, driver side Inner view of tie rod end zerk passenger side, this is behind center link Lower control arm rear, driver side Lower ball joint, driver side |
#22 |
Universal Joint
