05-25-2010, 10:03 AM | #1 |
Volts
I have a 1984 chevy C10 and just replaced the battery, alternator and starter and noticed the volt gauge reads 12V at all times this seems a little low. Can you guys give some input on what your volt gauge reads and what it should read?
Thanks |
05-25-2010, 10:07 AM | #2 |
Formerly- 1972SuperCheyenne
Re: Volts
Mine reads about 14 volts. Make sure you check all your grounds.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
05-25-2010, 10:41 AM | #3 |
Re: Volts
It should read 13.5v-14.5v
if I were you I would check voltage at the battery with it running. You might not have a proper functioning charging system
CHEVY ONLY |
05-25-2010, 06:03 PM | #4 |
Re: Volts
this happened to me for 2 weeks until i replace it yesterday night. mine had to deal with the connection to the ignition wire. I switched out the red wires because one was burnt by a malfunctioning alternator. then i red around 14-15 volts
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ] 1999 k3500 crew cab dually 6.5tdi/4l80e |
