Old 05-25-2010, 10:19 AM   #1
81ratrodc10
house of chevy's
81ratrodc10's Avatar
distributer?
i have a ? every couple of weeks my distributer comes loose and it can be turned i tighten the hold down but it seems to come loose again i dont know why this is happining any help thanx
81ratrodc10 is offline   Reply With Quote
Old 05-25-2010, 11:56 AM   #2
jchav62
1962 C-10
jchav62's Avatar
Re: distributer?
Strange. Maybe try using a little lock tite or something to keep it from backing out.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 05-25-2010, 01:00 PM   #3
81ratrodc10
house of chevy's
Re: distributer?
ya it is wierd the po told me it would run great then like crap couldnt figure it out i got home did a tune up on it and found out it was lose so i tightened it and it is still doing it ill have to try that
Old 05-25-2010, 01:33 PM   #4
78 Chevyrado
Re: distributer?
If the bolt isn't stripped, it may be half stripped... just enough to make the threads loose, but not enough to actually pull out. when you screw the bolt in without the bracket, can you pull it in and out at all?
78 Chevyrado is offline   Reply With Quote
Old 05-25-2010, 03:42 PM   #5
81ratrodc10
house of chevy's
Re: distributer?
i have never taken it out completly should i
Old 05-25-2010, 03:44 PM   #6
boatpuller
boatpuller's Avatar
Re: distributer?
yeah try that..or else run a thread cleaner down there the same size and try a new bolt.and some loctite.
" Never look up a dead dogs butt."
boatpuller is offline   Reply With Quote
Old 05-25-2010, 04:26 PM   #7
Chevytrux4me
Certified Gearhead
Chevytrux4me's Avatar
Re: distributer?
Is it possible that the hold-down may not be right-side-up? What about using a nylon locknut to secure it better and counteract vibration?
"I drive my pickup into the big city, 'n write my room number right on the bottom o' my boot. Jus' so I don't forget where I live. That's right, y'all. That's how I roll!"
Chevytrux4me is offline   Reply With Quote
Old 05-25-2010, 04:42 PM   #8
81ratrodc10
house of chevy's
Re: distributer?
how do i know if the hold down is wrong side
Old 05-25-2010, 06:33 PM   #9
81ratrodc10
house of chevy's
Re: distributer?
do i have to take the dist out to get the bolt all the way out
Old 05-25-2010, 10:20 PM   #10
Chevytrux4me
Certified Gearhead
Re: distributer?
I don't think you should have to remove the distributor to get the bolt all the way out. Some of the hold-downs I've seen have a slight curve to them, and should be installed with the two 'fingers' pointing downward.. However, some of the newer ones made out of billet alum and so forth I've seen are pretty much flat. I've wondered if the flat ones work as well as the curved. I was just thinking if the 'fingers' are pointing up and not downward, or if the hold-down is curved or flat. this might let the distributor bolt or nut loosen. I hadn't thought of it earlier, but I've seen hold-down bolts, and I've also seen a stud and nut setup. That's what I meant about the nylon locknut. Obviously, a bolt would need to be replaced with a stud to do that. Not knowing what's on your truck, you might want to look at the type of hold-down you have. Also, is there by chance a washer under it, as opposed to on top? Another thing to consider, this would require pulling the dist up, but I wonder if there's a gasket under the dist base, or is it possibly missing? I can see where this would let the dist base turn also. ...I'm by no means a master mechanic, just considering different possibilities of what might cause this.. Having worked on some trucks, tractors, and more than my share of old sports cars, I've seen lots of interesting 'stuff' over the years. I'm interested to know the outcome of this one.
Old 05-25-2010, 10:25 PM   #11
longbedrick
longbedrick's Avatar
Re: distributer?
loctite on your bolt and make sure you tighten your crows foot down real snug. get a crows foot tool if you can't get in there. I invested in them a couple years ago. good investment in tight places. if your intake is aluminum, be cautious not to strip your threads
longbedrick is offline   Reply With Quote
Old 05-25-2010, 10:51 PM   #12
81ratrodc10
house of chevy's
Re: distributer?
i have a performer rpm intake dont know if its aluminum and ill have to check and c how the crows foot os on there
Old 06-03-2010, 10:52 PM   #13
81ratrodc10
house of chevy's
Re: distributer?
okay so finaly got around to checking it out today the bolt is still tight but the dist still moves when i tightened it the first time the dist was tight not sure what it is
Old 06-03-2010, 11:06 PM   #14
Camaro_nut2001
Chevy Lover Till The End.
Camaro_nut2001's Avatar
Re: distributer?
Take the bolt out & flip your hold down piece over, you may have to use a longer bolt but see if it will tighten down the dist. If it does, go get you a knew hold down or just take one off another V8 Chevy motor. If the dist. gasket is missing or torn up you should have a small oil leak. Good luck.
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011
1989 Chevy Silverado, 4X4 - Daily Driver
1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck
1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original.
Members I've met: BamaBaxter,
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359
Camaro_nut2001 is offline   Reply With Quote
Old 06-04-2010, 10:09 AM   #15
81ratrodc10
house of chevy's
Re: distributer?
okay if the gasket is no good how do i change it
Old 06-04-2010, 10:37 AM   #16
silvereagle07
silvereagle07's Avatar
Re: distributer?
You have to remove the distributor to replace the gasket. Then you will have to set the timing but get a new hold down first. They are cheap. Do you have and pics of the way its mounted now?
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 06-04-2010, 03:37 PM   #17
81ratrodc10
house of chevy's
Re: distributer?
i dont have any right now but could get some
Old 06-04-2010, 04:31 PM   #18
68 TT
Still plays with trucks
68 TT's Avatar
Re: distributer?
I have seen distributor clamps that have been flattened out by people over tightening them over the years. The hold down bolt hole is only so deep so you can't tighten the bolt down enough any more to keep the clamp tight against the distributor base.
The fix is to put on another distributor clamp with more of the curve left in it.
This could be your problem or a combination of a bolt that is just barely too long and is not able to clamp down tight enough on the hold down to keep the distributor from moving on its own.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 06-04-2010, 04:41 PM   #19
81ratrodc10
house of chevy's
Re: distributer?
cool maybe tomarrow ill take the bolt all the way out and look at it
Old 06-04-2010, 05:37 PM   #20
silvereagle07
Re: distributer?
The clamp should have a slight bend. The originals are sprung steele and most chrome aftermarket clamps are cheap(they bend under pressure). You need a factory style with a bend or a beefy aftermarket clamp. The hold down on the right in the picture is how it should sit on the distributor.
Jeramy
'85 Chevy 4X4 SOLD
Old 06-04-2010, 05:44 PM   #21
81ratrodc10
house of chevy's
Re: distributer?
from that pic i think my hold down is no good going to look for sure tomarrow
Old 06-08-2010, 06:50 PM   #22
81ratrodc10
house of chevy's
Re: distributer?
well i finally got around to looking at it today unscrewed the hold down and it was flat bought a new one put it on no more turning set the timing runs like a champ now thanx guys for all your help
1987 m1028 cucv d30
2001 chevy s10
2000 honda shadow sabre 1100
"it's going to be an interesting ride home"
Old 06-08-2010, 06:57 PM   #23
68 TT
68 TT's Avatar
Re: distributer?
Glad it was something simple and that we could help.
Old 06-08-2010, 08:04 PM   #24
73chevyman
73chevyman's Avatar
Re: distributer?
mine does the samething but i forgot to put the gasket in lol
http://67-72chevytrucks.com/vboard/group.php?groupid=37
73 C10 Fleetside
If it ain't a Chevy it's foreign
http://hotridesmag.com/
73chevyman is offline   Reply With Quote
Old 06-09-2010, 11:00 AM   #25
68 TT
68 TT's Avatar
Re: distributer?
That just goes to show you how little tolerance there is for tight enough and not quite enough when it comes to the distributor.
