Old 05-25-2010, 11:56 AM   #1
873+3/90zuk
?'s for you diesel guys.....
Just got a 1987 1ton with a 6.2/th400. this is my first diesel of any kind and im pretty exited about it even though i dont know s@#t about these engines.
What can i do to it to get a little more power besides the exhuast and air cleaner? i want to keep it N/A for a while so i can figure out how she works before i do any kind of major upgrade like a turbo. She will also be my DD..
thanks
matt
873+3/90zuk is offline   Reply With Quote
Old 05-25-2010, 12:50 PM   #2
GmtGmt
Conversion Truck Addicted
GmtGmt's Avatar
Re: ?'s for you diesel guys.....
turn up the fuel abit thats about the only thing you can do besides a freeflow exhurst and a less ristriced air filter
give it a good tune up all filters and fluids
Thomas
Tonight mine pulled a few cars out of snowbanks, and is sitting in my driveway, icicles on the grille, wheels just white cakes of snow, buried up to the lug nuts in powder, straps and chains wrapped around the bumpers, the outline of the wipers clear in 4 inches of snow on the windshield... A tired warrior of the 1980s in a world of low profile tires, front wheel drive, and plastic bumpers, where people stay in their houses until snowplows move the offending substance from their paths, too helpless to travel without AAA and chains and salt, clearing their windows with longhandled brushes while gently stepping around in the snow trying to stay nice and dry.
GmtGmt is offline   Reply With Quote
Old 05-25-2010, 01:23 PM   #3
873+3/90zuk
thats what i figured. ive looked at a couple how to aritcles and it seems pretty easy to turn it up. Is 1/8 a turn a good amount or should i go more? If i straight pipe it will it be crazy load? i also read somthing about advancing the timing? is this a good or bad thing? also do they have smog equipment that can be removed?
Old 05-25-2010, 02:02 PM   #4
rcbildr
rcbildr's Avatar
I noticed a bit more power when I advanced my injector pump timing. I'm saving up for an egt pyrometer before I turn up the fuel.
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 05-25-2010, 02:28 PM   #5
873+3/90zuk
how do you advance injector timing?
Old 05-25-2010, 04:03 PM   #6
rcbildr
rcbildr's Avatar
There are 3 bolts that hold on the injector pump. Also look on the flange and you will see a mark...that's where it was marked when the pump was first installed. Just loosen the 3 bolts and turn the pump...don't do this with the engine running. I'll have to look in my books again to refresh my memory as to which direction advances it...IIRC turn the pump towards the driver side but let me double check that tonight and I will post up tomorrow.
My Projects:
1978 Camaro Z28
Old 05-25-2010, 05:19 PM   #7
873+3/90zuk
that would be great. how much do you advance it? from what i have read if I advance the pump/turn it up 1/8 turn, get a good air filter and straigt pipe it i should get a little more juice and it wont break the bank or make it unreliable.
thanks all
Old 05-25-2010, 08:09 PM   #8
68longhorn
68longhorn's Avatar
If your turning up fuel get a EGT gauge. Better to be safe than sorry
68longhorn is offline   Reply With Quote
