02-13-2003, 05:27 PM | #1 |
power steering box
Has anyone ever rebuilt a power steering box? I got a lot of play in the steering wheel.
02-13-2003, 07:55 PM | #2 |
Whats this wire for?....
I think they can be adjusted, not sure though...
Kyle CANADIAN CONNECTION '82 C10 Resto-Custom--> * 2 1/4" manifold back dual exhaust with Hooker Aerochambers & High Flow Cats *Taylor Ignition Wires *Centerline 15" Telstars with 32"x10" mudders |
02-13-2003, 08:01 PM | #3 |
I'm back with 2nd truck!
I was thinking about it but I learned that it's more trouble that it's worth. You sure the play is in the box?
1979 Chevrolet Bonanza Big10 "Tootsie Roll" 1985 Chevrolet Silverado (wife's) Member of the Southern Bowties Club "Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson |
02-13-2003, 11:24 PM | #4 |
LED King
I really think that they cannot be rebuilt buy a person without a massive workshop & specialty tools - Mine was just replaced last year - it started leaking from the shaft seal. I just ended up buying a rebuild one for around $60. You need to change the hoses out when you get a new pump. A new one cost $250!!! Ouch!
Edit: Uhh... nevermind the above - I was talking about the pump. I don't know about the box!
Tyler 1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles 2006 Ford Focus ZX3 5-speed Stick 2016 Chevy Spark EV Gone: 2002.5 VW GTI 24v VR6 Gone: 2008 VW R32 |
02-14-2003, 12:52 PM | #5 |
hahahha I hate when thats happens
Why do you say you need to change the hoses when you get a new pump?
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION * |
02-14-2003, 07:19 PM | #6 |
LED King
You really only need to change the pressure side hose - just a good preventive measure!
02-17-2003, 06:01 PM | #7 |
steering box
i was told that adjusting the box won't fix the amount of play I have. I already replaced half the front end.
02-17-2003, 08:06 PM | #8 |
an old gear box that is badly worn will ABSOLUTELY affect you steering. other factors that are just as important:
a-arm bushings inner tie rods outer tie rods pitman arm idler arm ball joints rag joint power steering pump/belt/hoses. the steering system is pretty much all inclusive. if anything fails, it will cause others to fail prematurely. domino effect almost. if in doubt, replace parts. better safe than sorry. |
02-18-2003, 09:33 PM | #9 |
I'll have to go back to the previous owners receipts(dad,mom)and see what they did.
02-19-2003, 01:08 AM | #10 | |
uh, no... none of those items will effect the play in the steering system in any way. they will however create more effort required to turn. |
02-19-2003, 06:48 AM | #11 |
there is a brass bushing were the shaft comes out of the bottom , it were's out over time . you cant adjust the worm gear to compinsate either.They sell rebuild kits , but I have never attempted this.
