05-25-2010, 06:13 PM | #1 |
wiper arms
i am having problems getting my wiper arms off. there is a thin tab at the
base of the arm i dont know if thats the release for it on not. |
05-25-2010, 07:10 PM | #2 |
Active Member
Re: wiper arms
Lift the arm up as high as it will go. You have to hold it in that position while prying the bottom off its pivot. Seems like you need three hands to do it but it will come off with some coaxing.
Warning: they may be stuck so it may require some serious prying or coaxing. I use a towel under a claw hammer or pry bar and ease it up. Try not to damage the paint. |
05-25-2010, 08:48 PM | #3 |
Re: wiper arms
There is a removal tool that works pretty well. Most "Help" sections in auto parts stores have them and you will not skin up your cowl using it.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
05-26-2010, 12:02 AM | #4 |
Re: wiper arms
thanks, paint is not really an issue and i did get off with out any damage to the cowl. and all it took was 2 screw drivers.
thanks very much Eric |
05-26-2010, 12:46 AM | #5 |
Old member
Re: wiper arms
This is the tool that makes removal a lot easier.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Tags |
67 c10, c10 2wd fleetside, how to, wipers |
