Old 05-25-2010, 11:47 PM   #1
j-dogg
Radiator retainer brackets - is this correct?
Here are some pictures of the radiator retainer brackets. They are the originals, but they don't look like they are fitting correctly to me. It looks like the U shaped portion on the bottom of the brackets isn't lined up correctly and is too flat, allowing the radiator to sit too far towards the engine. I know the radiator was replaced at one point, so there's no telling what the shop did to make the new radiator fit. The truck came from the factory with a heavy duty radiator according to the SPID. 70 C-10, 307, 2 barrel, no A/C. Sorry for the cruddy pics!
j-dogg is offline   Reply With Quote
Old 05-25-2010, 11:57 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Radiator retainer brackets - is this correct?
Looks to me like they are the wrong brackets. Looks like a four core radiator and three core brackets... That's probably why they put the rubber spacers between the shroud and the brackets.
LockDoc
Leon
Old 05-26-2010, 12:26 AM   #3
chev-obsession
chev-obsession's Avatar
I have a 4 core radiator on mine. The 3 core radiator brackets are shorter than the 4 core by quite a bit. That doesn't look right for some reason, some one had to do some work on that. The shroud is supposed to but right up against the brackets with no bushings of any kind.
here is some pics maybe they help?
1965 c/10 swb
1969 c/10 lwb
chev-obsession is offline   Reply With Quote
Old 05-26-2010, 12:50 AM   #4
Andy4639
Old member
Andy4639's Avatar
Talking Re: Radiator retainer brackets - is this correct?
You wreckin' they used a car radiator and mount?
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 05-26-2010, 01:00 AM   #5
jaros44sr
jaros44sr's Avatar
Looks like someone cut off the front part of the U channel that the rubber sits in...don't know why the shroud is sitting so far back. Probably 4 core mounts with a 2 core radiator
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 05-26-2010, 04:20 AM   #6
Andy4639
Old member
Andy4639's Avatar
Lightbulb Re: Radiator retainer brackets - is this correct?
This looks more like a factory truck radaitor than the top one does to me.
Old 05-26-2010, 11:56 AM   #7
chev-obsession
j-dogg's radiator looks like the one in my friends camaro. it may be a car one but you would think that a car radiator would not be as tall as a truck one. does it look solid on the bottom mounts too?
1965 c/10 swb
1969 c/10 lwb
