05-27-2010, 04:10 AM | #1 |
Muncie 3 speed with OVERDRIVE
Any body have a 1964 c10 with a 3 speed OVERDRIVE. Mine came with a over drive in it when I got it but I took it out and added a Doug Nash 5 speed in it now.
But I was to put my Doug Nash in my 31 coupe now and put my 3speed OVERDRIVE back in. Problem I have is: There was never a switch in the truck to ingauge the OVERDRIVE that I recall...I never drove the truck with that tranny in it.. How did they ingauge it? It was a factory install OVERDRIVE in that truck...
Measure with a yard stick Mark with Chalk Cut with a torch Built it yourself, don't count on others to to do it for you or with you. It will never get done Last edited by 63 & 64 Bowties; 05-28-2010 at 07:35 AM. Reason: language |
05-27-2010, 08:55 PM | #2 |
Re: Muncie 3 speed with OVERDRIVE
On a factory install, the only manual control was a cable with a T-handle mounted under the edge of the dash. With the handle pulled out, the O/D was inoperative. Pushed in, the O/D would engage automatically if you momentarily let up on the throttle at any speed above about 30 mph. Flooring the throttle would downshift the transmission to direct drive at any speed.
For full manual control, you can wire a toggle switch directly to the solenoid, but you should still have a cable, or else you won't have any way to lock out the free-wheeling when the truck is below the O/D cut-in speed. In other words, you can't park in gear with the handbrake off and expect the engine to hold the truck where it is. It will just roll away. I like these transmissions. If my truck had come from the factory with a column shift, I would have one of them in there now. Ray Last edited by raycow; 05-27-2010 at 09:00 PM. |
05-28-2010, 12:58 AM | #3 |
Nope there never was a lever on or around the dash....I looked everywhere....thats strange this truck was fully intact with only 44,000 mile on it...
Measure with a yard stick Mark with Chalk Cut with a torch Built it yourself, don't count on others to to do it for you or with you. It will never get done |
05-28-2010, 03:38 AM | #4 |
Somebody else must have gotten to it before you did. The bottom end of the cable attaches to a small lever on the left side of the tail housing. If you are lucky, the bracket for the cable will still be there.
Reproduction cables are available from some of the vintage parts vendors, but they are pricey. If you don't care about stock appearance, you can use a heavy duty choke or throttle cable from a truck or tractor supply. A car choke cable (if long enough) will also work in a pinch, but is a bit light. Ray |
05-28-2010, 11:28 AM | #5 |
Thanks Ray....Good Imfo....does your truck have a Overdrive. If so how do you like it...I have never driven one
05-28-2010, 01:22 PM | #6 | |
Ray |
05-28-2010, 10:50 PM | #7 |
I have a 3 speed with overdrive that installed behind my V6 305E in my 1966 GMC. In addition to being a bolt in swap, I am very happy with it. Although I have the cable (an aftermarket PTO cable works well), I never take it out of overdrive. The PTO takes it out of overdrive mechanically, I also have an on/off push/pull Cole Hersey switch on the dash that can switch out the overdrive electrically. The on/off switch controls a 30 amp relay that breaks the circuit to the electric solenoid on the left side of the transmission.
Around town, I typically shift 1st, then 2nd, then let the governor shift the overdrive in "automatically" when you let off the gas momentarily at 27 miles an hour. The overdrive reduces RPM's by 30 %. No more shifting to third with overdrive unless I am travelling over 40 MPH. If I slow below 27 miles an hour in second with overdrive, the transmission shifts out of overdrive back to 2nd. Cuts down on shifting in town. On the road with overdrive in 3rd, my engine RPM is reduced by 30% which keeps the engine from screaming at 55 or 60. If you have the tranny, it is well worth setting up. Ray is a great resource on these trannies and helped me when I put my in. Please e mail should you have questions or need additional information. Regards, Steve New Orleans |
05-28-2010, 01:20 PM | #8 |
I dont know much about those trannys but I dont think those came from the factory for that year. The 67-72 crowd will have a lot of info.
05-29-2010, 01:52 PM | #9 |
ok i feel stupid. anyone got a pic of this setup? is it an auto trans or manual??
05-29-2010, 04:26 PM | #10 |
Trevota:
It is a manual transmission. However, the overdrive is actuated electrically via a governor switch and an electric solenoid. Read all about it here: http://www.speedprint.com/deves50/overdriveindex.php Regards, Steve New Orleans |
05-29-2010, 09:28 PM | #11 |
good read, thanks for that. not trying to hijack the thread but what did those come in? and what will work in a 65 chevy with inline 6
05-30-2010, 02:07 AM | #12 |
fan of "Butters" Stotch
I had a 67 El Camino that had this setup with a 250 I6. The overdrive unfortunatley did not work when I got the car. I took it out shortly afterwards in favor of a 350/4speed setup.
It could not be real popular; I do not recall seeing one since
64 shortbox fleetside replacing rusty junk with more junk, and one day to become a real truck again Last edited by tapeworm; 05-31-2010 at 04:23 PM. |
05-31-2010, 03:04 PM | #13 |
I don't have anything scientific on the applications, but they were used from the mid 50's to the late 60's on full size GM cars and trucks. The early ones (pre 1966) had a four bolt side cover and unsynchronized first gear. The later ones from the late 60's had a seven bolt side cover and a synchronized first. Here is one on Craigslist from the late 60's. However, it does not show the governor or solenoid that sticks out from the right and left, respectively. These two parts are getting hard to find, so it would help to buy a transmission with these in good order. These overdrives (built by Borg Warner) were also attached to Ford and Chrysler transmissions, however the transmissions would not have the GM bolt pattern and are different. See Ford version as well in this ad:
http://orlando.craigslist.org/pts/1744730937.html Regards, Steve New Orleans |
02-17-2012, 02:15 PM | #14 |
Subscribed for future use....good info!
02-17-2012, 03:00 PM | #15 |
id love to see pics, as I have never seen one of these units in a 60-66.... great thread!
--Mike
63 C20 2WD, 230/SM420/4.11 73K 68 C30 dump truck, 327,SM425,4.56 66K original 68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes 68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79 69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi... 70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP 72 Chevy K20 4x4 350/350/205/4.56 donor 72 Vette 350/M21/3.70 posi, triple black and super fast 84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's |
11-05-2022, 12:33 PM | #16 |
I recently install the SM 319 w/ BW R-10 OD unit in my '66 GMC truck.. It's a terrific improvement give me better fuel economy and reduced my RPM on the highway from 3000 @ 70 MPH to 1800 @ 70 MPH.. Mine came from a 1958 Impala and with my 3:54 rear gears, my speedometer is still accurate.. Great set up!
11-05-2022, 04:00 PM | #17 | |
11-05-2022, 08:16 PM | #18 |
I have a 3-speed overdrive in my 63 truck and I love it. The overdrive units made by Borg Warner are quite tough and well built, but the connected Muncie 3 speed cannot take any serious horsepower. It is actually easier to get parts today, than it was thirty years ago when I first restored my truck. Borg Warner made the R10 which was a three pinion design and the R11 which was a four pinion design. The R11 came in several Ford products and the R10 in several Chevrolets and Studebakers and others. These units offer a significant RPM reduction in both second and third gear. For my truck with a 4:11 gear ratio, it drops the RPM from 3000 RPM at sixty miles per hour to 2000RPM. When overdrive is not engaged but not locked out, (under 28 miles per hour) the unit freewheels which allows for selection of 1st gear regardless of being non synchronized. I just enjoy the charm of shifting on the column and the ability to cruise down the highway at 75-80 MPH.
This company is selling a reproduction solenoid, relay and wiring harness as well: https://vintageautogarage.com/ Good luck with your install. Rick
RED RUMBLE 1963 C10 Chevy Truck Owned since 1984 |
11-06-2022, 01:43 PM | #19 |
I've had this transmission in my truck since I purchased it. My truck was a six cylinder from the factory but when I bought it, the PO had installed a 350 V8 out of an impala. I built that motor with Airflow Research heads, a Crane cam and a rotating assembly from Racing Heads Services. It has awesome power and torque and I used to drive it pretty hard. Two years ago, I broke the synchro drum speed shifting into 3rd gear at about 90 MPH. I then rebuilt a spare overdrive that I had with new bearing and seals. The gears were like new in it, not even any first gear chips. Now I am driving it more gently. I actually was able to find a complete gearset for the broken transmission and I rebuilt that as a spare. The overdrive section was still like new, but there was not a single useable gear in the transmission. Bottom line, I enjoy the overdrive and the column shift as well.
Rick
11-07-2022, 12:54 PM | #20 |
Another option to drop RPM on highways but keep column shift is to use a wide ratio Saginaw and a 3.08 r&p. The steeper first gear will still let it take off from a stop easily and the ratios aren't as wide spread as the stock three speed. You have to make new shift linkage and use a pull cable for the reverse lever.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
11-10-2022, 08:37 AM | #21 |
This is the trans I would have liked to see GM offer as an option on C 20's and C 30's. or a heavy duty C 10's used for towing travel trailers or heavier boats back in the day.https://www.motortrend.com/how-to/15...-transmission/ (Watch out for boat ramps 3 speed owners, they're clutch burners). Don't know if it will clear the frame cross member without some grinding or clear the standard 4 speed dog house on '63-'66 1/2-1 tons, because I have never tried it, and apparently nobody has tried it on this forum either. The trans was used on 60's medium duty trucks, so competent mechanic could have done this swap over the last 5 decades. unlike the NV 4500, which did not exist in this era. This is professional grade stuff, things the Big three automakers though you shouldn't need. To give credit, IH (International ) did offer a truck type 5 speed overdrive for certain model pickups in this era.
