05-28-2010, 01:05 PM | #1 |
A/C problem
Hi, I have a 99 Yukon with a 5.7. The A/C is not working. The clutch will engage and turn the compressor if I run a jumper wire to the front plug. It does get cool. I read about a sensor that may not let the clutch engage due to low freon, hi or low pressure. I am not sure where the sensor is. While I had it jumped, I added a small amount of freon. The gauge was pegged when I first started. Now it is reading about 50 psi. When I reconnected the plug, the clutch does not engage. I did not find anything after searching with my exact problem. Is there a sensor that may have gone bad? Where is it? Can I replace it?
Thanks for your help
Father and son built. Driven daily since 2012. 283, 3 speed. Mostly original. '81 PS and disk front. Fuel tank relocate. Maintenance, repairs and upgrades on his dime now. http://zacks64longfleet.shutterfly.com/ Higher res. photos in my gallery. |
05-28-2010, 05:19 PM | #2 |
Re: A/C problem
wooooo 50 psi on the low side is way too high should be around 35 psi on low side and 225-275 on high side at around 90 out side. the sensor is normally on the reviver drier
05-29-2010, 08:37 AM | #3 |
Re: A/C problem
Thanks for the reply.
I took it to Firestone yesterday afternoon. They told me the compressor is going out. By the way, it was working again when I drove it home and still this AM on the way to work. They want $900.00 to fix it. Can't do that. If the compressor is the case, I will replace it myself. I can get a new comp and clutch with 1 yr warranty for $220.00. I plan to replace the compressor and drier. Should I replace the sensor on the drier? It was listed on Firestone's estimate.
05-29-2010, 09:44 AM | #4 |
Re: A/C problem
compressor , drier and office tube, for warranty
06-02-2010, 09:27 AM | #5 |
"GO DAWGS"
Re: A/C problem
Do not go the cheap route. I made the mistake of putting on an Advance auto compressor and replaced it twice. After the second time I wound up putting an AC Delco one on and have not looked back in two years.
PT
70 CST SWB 70 NOVA 93 Indy 500 Pace Truck (SOLD) 94 SILVERADO SWB 5/7 drop 2000 Silverado swb 2005 Nissan Altima 3.5 (Surprisingly very fast) 2004 GMC Yukon XL Denali BATESBURG, SC. 29006 29006 Some of my restorations http://www.snapfish.com/snapfish/thu...NAME=snapfish/ Restored Tach tins 8 cyl - 6 cyl http://67-72chevytrucks.com/vboard/s...d.php?t=518185 Contact info(Not my paypal address) DAWGSFAN227@YAHOO.COM God Bless Our Troops Last edited by PT'S 70 CST; 06-02-2010 at 09:27 AM. |
06-02-2010, 11:39 AM | #6 |
Re: A/C problem
I learned my lesson years ago about replacement parts.
It's either AC Delco or nothing. The only thing I buy from Autozone is oil, and air freshners. |
06-02-2010, 11:22 PM | #7 | |
Re: A/C problem
[/QUOTE]I took it to Firestone yesterday afternoon. They told me the compressor is going out. By the way, it was working again when I drove it home and still this AM on the way to work. They want $900.00 to fix it. Can't do that. If the compressor is the case, I will replace it myself. I can get a new comp and clutch with 1 yr warranty for $220.00. I plan to replace the compressor and drier. Should I replace the sensor on the drier? It was listed on Firestone's estimate.[/QUOTE] Firestone can hardly fix a flat. Dont let inexperienced techs/greedy managers sell you somthing you dont need. Get the compressor enable curcuit working first (control head, low pressure switch, bad ground, A/C clutch relay, broken wire, etc). Charge it with the right amount of freon. What was the exact reason they gave for the compressor being bad or "going out" Last edited by clinebarger; 06-02-2010 at 11:24 PM. |
06-03-2010, 12:15 AM | #8 |
Re: A/C problem
1998 GMC Sierra SLE 1/2 ton 2WD 305 Vortec -Gibson Stainless Cat Back Swept Side -SS Wheels 2005 Honda CRF250R 2006 Honda CRF150F |
