05-28-2010, 01:34 PM | #1 |
1968 chevrolet c20 4 speed trans
I have a 1968 chevrolet c-20 292 6 cyl with the 4 speed manual trans and eaton rear axle. What type of trans is this? I am having an issue with not being able to shift from 2nd across to 3rd, is there an adjustment somewhere?
05-28-2010, 01:49 PM | #2 |
Junk Yartist
Re: 1968 chevrolet c20 4 speed trans
SM420- Reverse is left and down
Has One PTO cover SM465- Reverse is right and down Has Two PTO covers No adjustment, but they are both hard to shift if you are not used to them. |
05-28-2010, 09:39 PM | #3 |
If it is a 68, it should have a Chevy 465 or a New Process 435. The Chevy 420 was last used in 1967. The Chevy has a cast iron top while the New Process has an aluminum top.However, its possible there was a swap at some time and it may be a Chevy 420, if the 420 and 465 are interchangeable. No adjustments that I know of on all of the above.
05-28-2010, 10:18 PM | #4 |
have u checked fluid level? i got the sm465, it shifted better after i topped fluid off was a qt low.
