motor exploder
Hydroboost brake setup questions!
I have a chance to get a hydroboost setup from an '82 1 ton dually. I have built a solid roller cammed 468 BBC for my '69 shortstep (in sig below) and the hydroboost will afford me the luxury of not having to worry about vacuum for power brakes. Here's my setup so far, I'm just wondering if anyone has any experiece or can shed any light on this mix of parts:
I'm using '73-up CPP spindles with drilled slotted 1.25" rotors, POL D52 style dual pistons calipers in front. In the rear, I have a 12 bolt rear with Glocks' adapter brackets using '97 Camaro rear disc calipers (single piston PBR) with '96 Impala drilled/slotted rotors. For the engine, I'm using a serpentine setup from an '88 dually (7.4L, Mark IV) and I have the pump and all the accessories from this setup. Can I use the hydroboost from the '82 dually with the serpentine style power steering pump? Would I be better off finding a hydroboost setup from an '88-90 dually instead? I understand this may be a question better suited for the 73-87 section, I just wanted to see if anyone here could shed any light on this. Thanks in advance for any help offered.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! |
Re: Hydroboost brake setup questions!
I have no personal experience but I have read where people just use their original pump and T the return lines from the hydroboost and steering box to bothy go to the 1 return line on the pump.
With that being said I think I read somewhere that the hydroboost pumps have a little different valving/pressure to accomodate the hydroboost. Adding hydroboost to my Jimmy is on my short list so I am also interested in what others have to say. Captainfab also makes some hydroboost mounting brackets for swapping the hydroboost into our trucks.
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
#3 | |
Hollister Road Co.
This may be of some use http://www.thehollisterroadcompany.com/hydroboost.html |
I have a radical idea!
I don't know if you can use the standard pump, but I used a hydroboost power steering pump on mine. You will have to modify the mounting to fit the firewall, and lengthen the rod to use it on your truck. The mounting plate will have to be cut down to clear the steering column mounting plate, and you will have to drill 2 holes in it.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
Tags |
454, 7.4, dually, hydroboost |
