Old 05-30-2010, 10:41 AM   #1
ACII
Locating the airbags on the lower arms ok ???
Hello together....
sofar i want to install my airbags on the lower arms of my triangulated 4link suspension....as you can see on the pics...
I took this decision to get enough space for the exhaust to go above the rear axle to the rolling pan...
I saw this type of construction many times in the internet...but i am not sure about the big pressure on the lower arms and the rod ends, if they can handle it...
Furthermore what do you think about the ride quality with the bags on the lower arms infront of the rear axle ??
Hope to get some final advices to finish the rear axle project :- )
Thanks a lot
Achim from Germany
ACII is offline   Reply With Quote
Old 05-31-2010, 12:13 PM   #2
ACII
Re: Locating the airbags on the lower arms ok ???
nobody an idea ???
THx
Originally Posted by ACII View Post
Hello together....
Thanks a lot
Achim from Germany
Old 05-31-2010, 01:03 PM   #3
tcb-1
Nothing to see here.....
tcb-1's Avatar
Achim,
I recommend setting the air bag as close to the axle as possible. in the configuration you have shown, your creating a torque moment that will cause stress on the bottom four link trailing arm and the ride will be harsh.
I don't know if I've ever seen that many air ride/four link suspensions set ups where the bag is mounted directly to the lower link.
we should let some others chime in here that has four link experience.
!Guten Tag!
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 05-31-2010, 01:40 PM   #4
kunzy420
There is nothing wrong with mounting the bag to the lower bar. A lot of people suggest that, ride quality is better with the bag on bar as opposed to the bag over the axle.
How thick are the bottom bars?
kunzy420 is offline   Reply With Quote
Old 05-31-2010, 02:07 PM   #5
ACII
thanks for ur response.....
the size of the bottom bars are.... 1 3/4 inches .....furthermore i want to inforce the bottom bars with some gussets
So do you think this will be strong enough ???
THx Achim
Old 05-31-2010, 02:14 PM   #6
kunzy420
1 3/4" od is good for the bars, do you know the inside thickness of the bars?
Where did you plan on adding gussets?
Old 05-31-2010, 02:24 PM   #7
ACII
the thickness is 3mm
i want to inforce the bars for example like this:
http://www.google.de/imgres?imgurl=h...26tbs%3Disch:1
i am not sure if i should install the bags directly in the middle of the bottom bars or if the location on the pic should be fine ??
thx
Old 05-31-2010, 03:26 PM   #8
ACII
another question .....i have installed rod ends on the bottom bars...
I guess that will not work with the bags on the bars....cuz the bag will twist the bar ......or do you think if the bag is installed in the middle of the bar, it will not twist ??
Achim
Old 05-31-2010, 11:29 PM   #9
dv8customs
dv8customs's Avatar
Those gussets you posted would be great for your set up. The bag location looks to be okay as well. With as long as your bars are though you could probably move them a bit more towards the center and get a little better ride. I would recommend swapping the heim joints on the lower rods to bushings like you have on the uppers. If your bars are the same size just swap the ends on your lowers to your uppers.
dv8customs is offline   Reply With Quote
Old 06-01-2010, 12:30 PM   #10
ACII
Ok ... i will put the bags on the center of the bottom bars..
Do you think it is enough to swap just one side of the bottom bars to bushings ?? cuz the bottom bars are not square to the rear axle.... !!!
Thanks for ur support
Achim
Old 06-02-2010, 11:26 AM   #11
ACII
i hope to get soon one more advice about the bushings on just one side of the bottom bars... see my last question above
So i could immediatly start with the final steps
Thx
Achim
Achim
Old 06-02-2010, 12:42 PM   #12
dv8customs
dv8customs's Avatar
It would twist less but I still don't think it would be ideal.
Old 06-02-2010, 12:48 PM   #13
draggin86
draggin86's Avatar
make sure the bag is exactly centered on the bar.. i have used 1 3/4" .120 wall with bags on the bar with no issues at all. as far as location i would say that is a little far forward.. you have to think of it as a lever the further away from the axle you get the more the lift you will get but the more pressure it will take to get there. 1/3-1/2 of the way from the axle on the bar should yield a good ride along with keeping a good suspension travel
draggin86 is offline   Reply With Quote
