![]() Join Date: Oct 2009
I'm finally to the point of hooking everything up to complete my power brake upgrade. So, it appears that I have 2 possible vacuum sources to tap into. One on the outside of the intake that goes to the transmission and one on the inside of the intake that goes to the pcv valve. (There's a third that goes to the vacuum advance, but I know that one isn't a good choice due to the small size of the fittings). Does it make any difference? Also, what kind of T fitting should I use? Thanks guys!
![]() Upgrades: Power steering, Offset air cleaner, Rear Sport bumper, 3 point safety belts, HEI, -1/-2 springs, 16x5 wheels, McGaughy's disc brake conversion, Sway bar |
Re: 250 Brake booster vacuum source
There is a pipe plug on the side of the intake manifold. Pull this plug & put in a fitting for a 3/8 vacuum hose. Hook this to the power brake unit.
right on the money,I run my vacuum booster from the manifold & works great! I never thought six sillys made enough vacuum for a booster but they do! cheers, Pat
Tot Roddin'
Not aware of which vacuum you will need, but would love to see some pics of your setup under the hood. You have added some great pieces to your inline, and would love to see them.
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
I am a Referee of life.
What Wrenchbender said.Come by if you want to look at mine.
BlckButy,his truck is in awesome original condition minus the fatory optiuons he has added.I've ridden in it and it feels like it might be the year 1969.It is clean and rides like it did when it was new.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
I'll have to post a pic when it's back together. I wanted to replace the lines while I was at it, but they left out one of the front lines when they sent them. I'm hoping to get the missing line and put everything back together next weekend, but I don't know how much time I'll have.
PD, Thanks for the kind words! I can't have an indoor party in the back of mine though.... ![]()
I've been meaning to post this pic for Nate (72Blckbuty).
I don't know what I want to do next...suspension, wheels, ignition, a/c. Decisions, decisions.
#8 | |
Tot Roddin'
And... (cough, cough) suspension. ![]() Are you planning on keeping it all stock or lowering it, upgrading wheels?
if u don't mind me asking how much was your new brake booster and master cylinder and who'd you order through. im upgrading to disc in the rear and since im getting a new prop valve to been considering getting new booster and master cylinder too. the ones i got work now but thought it would be smart to upgrade. thank you and the truck looks great from pics ive seen around.
I wouldn't mind for it to be a little lower, but not a lot. From what I've seen in other posts, going back with stock height springs really elevates it. I'm thinking about 2/4, which probably would look good with stock height tires. I really want to continue running the original hubcaps, so I'm thinking about having some 15x7's made. I might go with 15x7 in the front and 15x8 in the back. I've even been looking for some local Rally's to run for a while, but 15x7 6 lugs are hard to find. It's a tough decision.
![]() Join Date: Nov 2001
The original 67 250 fan not sure what the size is but I'll check in the morning. What brand clutch fan yo using. Thanks.
It's a stock fan clutch that I got from a local yard. I was really after the fan. The clutch felt good, so I decided to use it. I'll measure it again and look for a part number on the fan.
Yep check my four blade fan and it's 18 inches.Sorry for going off topic but was fan clutch off a six cyl and sorry to ask but do you know for fact it's a V8 shroud. I ask cause my friends 68 6 cyl auto has a factory fan shroud which I seem to be finding out is rare. I tried the V8 shroud myself and the fan scraped just a slight bit. Never did measure my friends fan blades. Thanks again. Nick
#14 | |
#15 |
Here's a little more info on the fan blades I'm using:
•The 3947772 fan replaced the 779 fan and had a 2.25" pitch. It was produced by Schwitzer and was used during the remainder of the production year (and through the early 70's) and has the part number and month / year stamped on the fan blades. This was pulled from the following Camaro site: http://camaros.org/coolingsystems.shtml I hope this is helpful.
#16 | |
3947772 914087 H72 I think this was a stock fan on a lot of cars with a/c. Also, while test fitting the fan shroud....I think I recall that my stock 4 blade fan also rubbed. I can take pictures for you if you think it will help.
![]() Upgrades: Power steering, Offset air cleaner, Rear Sport bumper, 3 point safety belts, HEI, -1/-2 springs, 16x5 wheels, McGaughy's disc brake conversion, Sway bar Last edited by NC67Chev; 07-21-2012 at 08:26 AM. Reason: Add additional info |
