I now have steering!
I have been tinkering with the truck on and off for what seems like forever. Cross steering off the "TO DO" list. I got the heim joint welded in and it all clears the headers without binding. I ran my truck for years and then took it apart to do body work and one thing led to another. I wanted headers but took a short cut before so I put in the headers and re-routed the linkage. Should sound alot better now, no to mention a few extra horses. There is plastic wrap covering the valves as I took the valve covers off waiting for a new set to arrive.
One day I am going to finish this project! 1949 Chevy 1/2 ton |
Re: I now have steering!
I am having issues getting the pics to post! AGHHH
I hope this works.
This is the last pic.
Cancer Survivor in the making.
Steering is like my second favorite things right after brakes. Good work!
'55 1st GMC Suburban - '54 GMC 1-ton trailer puller (in process) - '54 GMC 1-ton Hydra-Matic - '47 Chevy AD COE and lots more rusty old iron. Steve@OldSub.com OldSub.com . MaxwellGarage.com . OldGasTowRigs.com |
tobins 52 gmc
I have the same headers , are you using a mustang 2 front end .thanks Robert
I do have the mustang II front, sbc, 700r4, 10 bolt rear. I have another 10 bolt from a 67 camaro, posi and 3:43 gears. It is going to get disc conversion and go in after I get her back up and running. I ran her for years with a bad body. I took her apart and am now adding "upgrades", power windows, shaved, relocated gas tank.
Spanked once
![]() Join Date: Oct 2006
Looking good and Tight.I used Sanderson cast headers on mine and was able to find some really close bent 2 1/4 elbows from jegs to put my flanges on. That things gotta be a hoot with that drive line.
The ole 350 budget build. |
hey i know this forum hasn't had any activity for almost a year but i just saw that you said you relocated your gas tank. Just curious to what tank worked for you and im assuming you put it under the bed? Thanks
Moderator
![]() Join Date: Jul 2006
Must have sucked driving around all those years without steering huh? j/k looks good, I have to do the same thing.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
Is that the proper phasing for those U joints? Curious?
It clears everything and it does not bind. If thats what you mean by phasing. There is a great article in the classic truck magazine putting in a suburban tank, I used the mustang tank in the rear of mine.
thanks, do you happen to have a link to that classic truck article about the suburban tank article or a date when it was published?
