Old 02-14-2003, 12:17 PM   #1
dubie
dubie's Avatar
Breaking a 3 spd tranny from the engine
I was just thinking about this and had a couple questions
I know with an automatic, you remove the flywheel cover, remove the flywheel bolts, then remove the tranny bolts and break the 2 apart. But with a manual tranny, are there any extra steps? I have heard that there is a release bearing to watch out for?? Any ideas on this guys? Oh, I will be splitting a 3 spd from a 250 inline and then bolting the tranny onto a 350.
Thanks guys
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 02-14-2003, 12:56 PM   #2
Brad
Out of the carpool lane.
Brad's Avatar
Sounds like you've messed with removing trannys before? You shouldn't have any problems. I've done this but can't give you any specifics. It's pretty basic, nothing you should look out for.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 02-14-2003, 01:03 PM   #3
dubie
dubie's Avatar
I used to work as an auto wrecker. Oh I mean auto recycler gotta be politically correct Thanks Brad
Old 02-14-2003, 01:40 PM   #4
Gordo
Smile
The 350 will require a pilot bushing in the back of the crankshaft if the engine was not previously set up for a standard trans, and even if it was, it would be a good thing to replace it anyway.
1971 C10 swb stepside 350/700R4/3.73posi (retired as of 4/22/03)
1998 S10 short bed
2002 S10 Blazer
1942 Oldsmobile
1958 Massey Harris Pony
1951 Wife
Killingworth, Connecticut
May those who love us, love us, any of those who do not love us, may God turn their hearts.
And if God is unable to turn their hearts, may he turn their ankles so we may know them by their limping.
A man who works with his hands is a laborer; a man who works with his hands and his brain is a craftsman; but a man who works with his hands and his brain and his heart is an artist.
Gordo is offline   Reply With Quote
Old 02-14-2003, 01:52 PM   #5
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
Pulling a manual trans is basically the same as pulling an automatic. Only you don't have to mess with the tranny cooler lines. You get a choice of pulling it with or without the bell housing. The only thing that might give you problems is the clutch release bearing, it could hang up on the input shaft it you pull the tranny away from the bell housing. If you take bell housing and all, the only thing you have to worry about is the input shaft sliding easily out of the splines in the clutch. (They don't usually give too much trouble in a car or pickup, but I've seen them stick in big trucks and they are a bear when that happens)........I always put a little anti-seize on the splines when I put them back together for easier installation and to prevent the stuck input shaft problem.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
