Old 06-02-2010, 08:13 PM   #1
pseudopimp
pseudopimp's Avatar
replacing front wheel bearing 4x4
I have an 84 K10. I am replacing the front wheel bearing. when I removed the hub, the housing was packed full of bearing grease. when I replace the bearing, do I pack the houseing with grease also, or is a well packed bearing good enough?
pseudopimp is offline   Reply With Quote
Old 07-09-2010, 11:33 PM   #2
CussinDusty
CussinDusty's Avatar
Re: replacing front wheel bearing 4x4
You need to grease the whole inside of the hub,not just the bearing
http://i957.photobucket.com/albums/a...sty/sig2-3.jpg
87' Blazer
36"TSL SX,
Bedline'd Interior,and bumpers
Heddman Long Tubes,True Dual Flowmaster 40's
4:11's locked
Build Thread-
http://www.fullsizechevy.com/showthr...r-Build-Thread
CussinDusty is offline   Reply With Quote
Old 07-10-2010, 11:37 PM   #3
fire120ball
fire120ball's Avatar
look at it like this... more grease, never hurts
73 Chevy k10 In progress http://67-72chevytrucks.com/vboard/s...52#post3552552
2000 Trans Am, ls1, 6 Spd http://ls1tech.com/forums/appearance...years-old.html
fire120ball is offline   Reply With Quote
Old 07-10-2010, 11:54 PM   #4
cheepin
You don't need to pack the whole thing with grease.You just need to clean and pack the bearings really good.If you needed to fill it they would have a zerk fitting on it.
1984 1ton 4x4 crew cab dually 6.2 diesel,465,205,D60,D70,1987 3/4ton 4x4 suburban 5.7 FI350,TH400,208,1985 CJ-7 FI406,465,205,D60,FF14, 1970 Jeepster 350,465,205,D44,FF14,
cheepin is offline   Reply With Quote
