Old 06-02-2010, 10:09 PM   #1
Silence86
Silence86's Avatar
under hood ac pics?
i need some pics of the ac compressor and where the hoses and all that go under the hood. i will be getting mine fixed for the summer and when i took it out i didnt take pics or anything thanks in advaance guys
1986 gmc sierra....http://67-72chevytrucks.com/vboard/a...hp?albumid=622
Silence86 is offline   Reply With Quote
Old 06-02-2010, 11:57 PM   #2
datguysaL
Re: under hood ac pics?
hope this helps..
datguysaL is offline   Reply With Quote
Old 06-03-2010, 07:45 AM   #3
RandyP
Getting Old; Going Broke
RandyP's Avatar
You wanting what it should look like or with the serpentine setup like datguysaL is showing? Here's under the hood of a stock 87.
RandyP is offline   Reply With Quote
Old 06-03-2010, 08:37 AM   #4
Silence86
Silence86's Avatar
thats just what i was looking for thank you
Old 06-03-2010, 10:25 AM   #5
Slick17
Slick17's Avatar
Do you know of a good cheap place to get all the parts under the hood. I bought the truck and the person took all the A/C stuff off. I still have the canister and the cooler by the radiator but none of the hoses or compressor.
05 Chevy 3500 Crew Cab Dually
Sold 1984 Custom Deluxe K/30, 350 SBC with 4 Speed, 6" Lift, 35" Boggers, Headmen Headers, Custom Full 3" Dual Exhaust, Qualitex Buckets with Flip Center Console
Slick17 is offline   Reply With Quote
Old 06-03-2010, 11:42 AM   #6
OleBlue79
OleBlue79's Avatar
Go to O'Reillys or Autozone. You cane get everything but the "liquid line" that goes from the evaporator to the dryer. You may have to find one in a yard and have the ends fabbed up on a new one from an AC shop.
OleBlue79 is offline   Reply With Quote
Old 06-03-2010, 02:04 PM   #7
LOW1TON
here is mine, seems I have a different compressor than most, might be because of the 454, or that my truck is fuel injected and not carburated. Hope they help.
"WIDER IS BETTER" (TRUCKS ONLY)
LOW1TON is offline   Reply With Quote
Old 06-03-2010, 03:02 PM   #8
Silence86
Silence86's Avatar
wow!!! very clean!!! i need pics of the compressor connection(electrical) or can someone tell me the colors???
Old 06-03-2010, 03:57 PM   #9
Slonaker
Insert Witty Text Here
Slonaker's Avatar
The photo in this other thread may help.
http://67-72chevytrucks.com/vboard/s...d.php?t=405826
Different years of trucks from the 80s route the hoses differently. My '86 routes them across the engine but earlier ones go across the fan shroud. You should be able to use whichever one you like best.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 06-03-2010, 04:38 PM   #10
RandyP
RandyP's Avatar
Green and black is what mine are.
Line routing has mainly to do with age and then engine, FI or carb should be irrelevant. I know between the 84 we have here, and my 87 (which is FI like a stock 87 should be) the lines are identical as is the routing. Can't compare to the 79 since it is a nonAC truck.
