Old 06-04-2010, 06:39 PM   #1
Groyd
Groyd's Avatar
Amateur Build In Progress
I picked up a 1951 Chevy 5-window for a decent price just to learn "how to build a truck," about a year ago. I've never welded or done any body work. All I've done is read a lot of posts. Decided to go the S-10 route. It's been a lot more expensive and time consuming than I thought.
Went with the EZ-Chassis Swap Since I could never fabricate something like this. As simple as it is, it still took us a couple of weekends to get it all on the frame. Like I said, I've never welded so my dad is teaching me as we go.
Previous owner literally poured concrete in the drivers cab corner to fill the rusted holes. I had to chisel it out. Went ahead and had the cab media blasted.
Sprayed some etching primer.
Now we're in way over our heads cutting out the cab corners. We're trying to lip weld them because it is supposedly easier. I got the corners tac welded in place and we couldn't get the door to fit and had to take it off. Any helpful suggestions are appreciated. Keep in mind that I'm a novice with minimal tools/experience.
I'll be slow with updates, because we are slow with our work
Thanks.
Groyd is offline   Reply With Quote
Old 06-04-2010, 06:59 PM   #2
C low
C low's Avatar
Re: Be Gentle. . . I'm an Amateur.
Sweet man! Every one has a first build myself included keep at it and you will be a pro before you know it.. As for cab corners i tack tabs (from the inside) in and make it flush then you would have less filler
C low is offline   Reply With Quote
Old 06-04-2010, 07:01 PM   #3
Southcity
Southcity's Avatar
Exactly what C Low said, we all had to start somewhere and you are lucky, you got your Dad around to show you a thing or two. Keep up the great work and good luck!
66 GMC Suburban Custom
66 Chevy K10 Suburban
Southcity is offline   Reply With Quote
Old 06-04-2010, 07:39 PM   #4
54 jimmy
54 jimmy's Avatar
goin the club. both the corner on my 54 were filled with concrete too. must have been common thing on theses trucks.
There is nothing you can't fix with a BFH or a FIRE WRENCH.
1997 chevy k1500 ext cab z71 (daily driver) sold
1996 chevy k1500 reg cab 4x4(daily driver)totaled
2008jeep patriot (wife's daily driver
2008 chevy 1500 ext cab 4x4 sold
2011 chevy 1500 crew cab ltz (daily driver)
1996 chevy 1500 reg cab 4x4 project sold
2006 pontiac grand prix gxp (daily work commuter)
54 jimmy is offline   Reply With Quote
Old 06-04-2010, 07:42 PM   #5
bjcaldwe
bjcaldwe's Avatar
On my previous cab, one corner had, bondo, fiberglass and brass lol. Just keep at it and you will get there. Once I get back started on mine, I will be dealing with the same learning curve.
My AD Truck Build Thread
52 GMC one day laying on the running boards
2004 Chevy Crewcab. 3/5 and notched
bjcaldwe is offline   Reply With Quote
Old 06-04-2010, 07:44 PM   #6
Steve@OldSub.com
Cancer Survivor in the making.
Steve@OldSub.com's Avatar
Welcome! You can always come here and ask questions when you find challenges. Even experienced guys with lots of builds behind them do that.
'55 1st GMC Suburban - '54 GMC 1-ton trailer puller (in process) - '54 GMC 1-ton Hydra-Matic - '47 Chevy AD COE and lots more rusty old iron.
Steve@OldSub.com
OldSub.com . MaxwellGarage.com . OldGasTowRigs.com
Steve@OldSub.com is offline   Reply With Quote
Old 06-04-2010, 08:20 PM   #7
jeffs51chevy
jeffs51chevy's Avatar
Groyd,
If you do some searching, you'll find my first attempt at building a truck. I too went the s10 route, thinking less money and a fews weekends of time would yield a drivible piece of Americana. Fast forward two + years and I still have an steel dream my wife doesn't understand. Through all of the head scratching and cus words, I have learned that if I give it enough time and effort, I will get something I'm truly proud of; not something from a shelf. That should be your focus. Ask as many questions as you can, and learn from your mistakes because there will be a few. This board is as nice as they come. Good luck and keep moving forward. We have all been, or are standing now, in your shoes.
Jeff
jeffs51chevy is offline   Reply With Quote
Old 06-04-2010, 09:08 PM   #8
Sillyoldman
#16876
Sillyoldman's Avatar
First, Welcome to the board. Second, Slow? Wow you are moving at the rate of a gazelle. If you can't get to sleep see my build thread (link below) it started three years ago and it's way far away! Good job.
Posted via Stationary Device
'71 Custom Deluxe C-20 402.
'67 Buick Special 455.
'49 Plymouth Special Deluxe.
"I love that old car smell"
Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
Sillyoldman is offline   Reply With Quote
Old 06-05-2010, 02:17 AM   #9
T Hilde
My cab was loaded with rat $h!t.
T Hilde is offline   Reply With Quote
Old 06-07-2010, 03:08 PM   #10
Groyd
Groyd's Avatar
I forgot to mention. I bought a 5.3 out of an '04 GMC from my cousin. Engine, trans, and computer. He said he could wire it up. I guess we'll see once were done with this cab. I'll try to get a pic of it up tomorrow sitting on the frame.
Old 06-08-2010, 09:23 PM   #11
Groyd
Groyd's Avatar
Amateur Build in Progress.
Sat it in the frame just to get an idea if my motor mounts would work with the LS type engine. Still won't be certain until we get the cab in place. Kind of hard to do since the body is at my parents house.
I'm going to have quite a bit of slide room if it needs adjustment forward or backward.
Old 05-08-2012, 01:44 PM   #12
altereddezignz
Re: Amateur Build in Progress.
What mounts r those. i know the lower frame mounts are the ez kits mounts have the same ez kit but am using a motor and trans from a 99 truck?
altereddezignz is offline   Reply With Quote
Old 05-08-2012, 08:01 PM   #13
Groyd
Groyd's Avatar
The mounts from the motor are LS plates to SBC mounts (I believe they were Trans Dapt brand). Then, like you mentioned, the S10 Frame to SBC mounts from EZ.
1951 Chevy 3100/S-10:
http://67-72chevytrucks.com/vboard/s...d.php?t=406072
1957 Chevy 3200
1971 2WD Blazer - Sold
Old 06-08-2010, 09:49 PM   #14
Kabwe
Certified Car Nut
Kabwe's Avatar
Looking good keep up the good work.
Kabwe is offline   Reply With Quote
Old 06-09-2010, 11:12 AM   #15
kustombrad
kustombrad's Avatar
Dude! Very nice! Keep plugging away and it will be a driver.
It's all about the stance, baby!
http://67-72chevytrucks.com/vboard/s...d.php?t=320546
kustombrad is offline   Reply With Quote
Old 06-17-2010, 05:50 PM   #16
Groyd
Groyd's Avatar
Since the doors wouldn't shut with the cab corner tac welded in place. We had to remove the corners. . .again. . . and try to fit the doors. Needless to say, the hinges and latches were shot. I had already ordered some replacement latches.
We got the latches and new hinges installed but we're still having trouble lining up the door to shut. Any suggestions on how to line up the doors? Has anyone used washers to shim up the mounts?
Top of driver's side door:
Looking down on passenger's side:
Old 06-17-2010, 08:01 PM   #17
cajundragger
if you havent rebuilt the hindges start there. Then hang the doors.
cajundragger is offline   Reply With Quote
Old 06-17-2010, 08:18 PM   #18
Groyd
Groyd's Avatar
We installed new ones. Still having trouble though.
Old 06-17-2010, 08:23 PM   #19
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Yes you can use washers or go to a body parts supply house and get some shims. You can cut slots out of washers as well but the shims are easier to use since they have a tab to hold on to them or grab them. Atleast you hung the door before you welded the cab corner on. A lot of people don't do that and have to cut the complete patch out and start over. Nice job, and keep up the great work!
Ryan
1969 Chevy milk truck
Old 06-18-2010, 11:43 PM   #20
Breader
Breader's Avatar
your making some nice progress keep up the good work.
Breader is offline   Reply With Quote
Old 06-20-2010, 01:23 AM   #21
pgf545
pgf545's Avatar
Welcome, I think most of are amateurs here. I know I have a lot of mechanical knowledge but the body stuff is driving me nuts. I did the cab corners, front floor, firewall and outer cowl on my dads 52. The thing I am learning about all these replacement parts is that you don't have to use the whole panel. I am hard headed so I tend to think that I have to use everything the ship me. If I had to do it over again I would only use what was needed to replace the rust. I think I have some pictures of the door hinges that I rebuilt on my build thread. If not let me know and I will see what I got here on the computer. Another thing with the hinges is that you may have to loosen the bolts that hold the door to the hinges and jockey the door around. I think I messes with the drivers door for a full day before I got it where I wanted it. Good luck and don't hesitate to ask questions there are lots of knowledgeable people on this board.
Bernie
52 Chevy Truck (Dad's)
http://67-72chevytrucks.com/vboard/s...d.php?t=206021
pgf545 is offline   Reply With Quote
Old 06-20-2010, 12:37 PM   #22
playinsafe44
This guy showed how he got his doors aligned. It looks like you will have to tweak your hinges too. Hope this helps http://www.chuckthetruck.com/page20.html
playinsafe44 is offline   Reply With Quote
Old 06-20-2010, 07:39 PM   #23
Groyd
Groyd's Avatar
Thanks for the link. It looks very helpful. We'll give it a try later this week.
I think we've come to the agreement that it would be better to pay a body shop to fix our body work and door problems if we can't figure it out pretty soon. I'm pretty cheap though, so we'll see.
Old 06-21-2010, 11:00 AM   #24
bjcaldwe
bjcaldwe's Avatar
Have you checked out the Oklahoma section? We have been talking about trying to go to some of the Coit's cruise nights around the metro. I am happy to see another AD truck up here, especially one making more progress than I do lol.
Old 06-23-2010, 06:10 PM   #25
Groyd
Groyd's Avatar
Sounds like a good idea, bjcaldwe.
