06-05-2010, 01:04 AM | #1 |
transfer case interchange
i am currently working on a project that started with a 1977 K5 blazer drivetrain under it and have swapped out the axles already. what i am wondering is if a t-case from a 1984 1/2 ton with a 700r4 tranny will mate up to the 1977 turbo 350 tranny that i have splining and all? the 1977 is currently a full-time chain drive and i would like to go to the part-time aluminum gear drive.
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you." '84 chevy half ton short box 2wd, 67,000 actual miles '03 chevy 1500 HD crew cab 4x4 standard box, 6.0L |
06-05-2010, 03:17 AM | #2 |
Re: transfer case interchange
off the top of my head I couldnt say for sure if the spline is right and I am pretty sure you'd need a different adapter..
For an idea.. why not put a 205 on... a few dollars more and it would be WAY heavier duty to go with the axles... |
06-05-2010, 03:45 AM | #3 |
Sb 400 club
The splines on the Trans output are 27 which i believe is the same between a th350 and a 700r4. The 700r4 uses a longer transmission output shaft. The 700r4 would be mated to a np208. the 208 is also a chain drive unit. It is lighter and uses a lower low range which is nice for offroad. But it is still weaker because it is chain drive and aluminum. I swapped in a np205 which is gear drive and cast iron with a th350 adapter and 27 spline input.
1984 chevy c10, built 400sb,.(SOLD) 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
06-06-2010, 01:09 AM | #4 |
bikes&bowties....i know the 205 would be ideal, and am planning to go that route eventually....the reason i was asking is cause i have the aluminum t-case sitting in my garage.
84 400... so the 208 should mate up to a th350 just fine then? the reason i am asking is cause i don't wanna drop the heavy cast iron turd only to find out i am gonna have to put it back in.
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you." '84 chevy half ton short box 2wd, 67,000 actual miles '03 chevy 1500 HD crew cab 4x4 standard box, 6.0L Last edited by lurch115; 06-06-2010 at 01:10 AM. |
06-06-2010, 02:34 PM | #5 |
No, the th350 output shaft is not long enough.
-Andy '77 K5 Blazer '78 K10 Shortbed '78 C20 Suburban '79 K30 Crew Cab Dually '84 C10 Short Stepside '88 K20 Suburban |
06-06-2010, 04:08 PM | #6 |
The TH350 has 2 different 4x4 shaft lengths.
One is used for the 203 and 205 cases and the other is longer and is for the 208 tcase. |
06-06-2010, 04:10 PM | #7 |
high-Tech Red Neck
save yourself the trouble and get a 205. the 208 is very very very very weak. if it breaks out where you are offroad and you have to hire a wrecker to get you home, it will have been cheaper to get a 205. I bought one this morning with a TH350 attached for 300 bucks. They are around, you just have to look.
"He used to be a pretty nice feller, now he's a welder!" |
06-15-2010, 12:03 AM | #8 |
thanks for all the info. i am planning to sit under it here soon and check to make sure the linkage isn't out of adjustment also.
