![]() Join Date: Jun 2009
'72 c10 suspension upgrades
Looking for tips on suspension upgrades for better handling on my stock 1972 Chevy C10, 307, 4 speed manual, swb fleetside. I do not plan on carrying anything heavier than my 500 lbs motorcycle. Thanks.
Happy to be here
![]() Join Date: Mar 2000
Re: '72 c10 suspension upgrades
I will assume that the truck posted in your profile is what your looking to improve. If that correct lets look at what you can do.
Lowering a trucks center of gravity always improves its ability to take a corner. A mild drop and the addition of a factory sway bar will show good bang per buck return on investment. I prefer to run dropped spindles in front and shackles in the rear of leaf spring trucks. It looks like your tires are fairly new so I doubt you want to change them. If you would consider that option, a lower profile tire will have less flex, and diminish body roll. You don't have to run rubber band style 25 series tires to notice a difference. I have found that a 45 or 40 series tire will still give a good ride yet tighten the roll resistance up quit a bit. Shocks are a another option to consider. That is huge and usually controversial subject, so I won't attempt to go there. Just know that at some point you should consider going to a premium quality shock and might consider something that is adjustable. Questions? ![]()
Thanks N2 TRUX,
I have a 1 1/4" front sway bar from a ton that I planned on installing and was considering 2 1/2" drop spindles and shorter spring for the back, from Early Classic. What length springs would you recommend for the rear? Would I need any other parts like shock relocating kit or a new adjustable panhard bar? |
Grandpa in the rustmobile...
they make a 5" kit with everything you need. while your there id replace trailing arm bushings and weld trailing arms together!
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
